Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Contexts and keyboard key
4 REPLIES 4
egoldid1
970 Views, 4 Replies
egoldid1
hi, i have written one Contexts....
in this my Context i have MEvent::kMiddleMouse or MEvent::kLeftMouse...
now, how i can have MEvent::yKey( y key of keyboard):smileylol:
or how can i know what key is pressed by user?
4 REPLIES 4
in reply to: egoldid1
Create a hotkeySet with commands bound to the keys which are of interest to your context.
In your context's toolOnSetup() make your hotkeySet the current one.
In your context's toolOffCleanup() restore the old hotkeySet.
Alternatively you can use qApp->installEventFilter(...) to install a Qt event filter which looks at the keystrokes as they come in, but you need to be careful that you don't deadlock Qt's event loop or starve Maya of events. Unless you have some compelling reason not to, I'd recommend using the hotkeySet approach.
stuzzz
stuzzz
Hello Joe,
How do you create that hotkeySet with API? Can you give some more details?
Is that with the MGlobal::executecommand()
Cheers.
Hello Joe,
Cheers.
in reply to: stuzzz
We do it in MEL proc which is called by the context's toolOnSetup() and toolOffCleanup() methods using MGlobal:executeCommand() . The script containing the MEL proc is sourced by our plugin's MEL initialization script.
The essence of the MEL proc is:
global proc setHotkeys(int $enable)
    global string    $gOrigHotkeySet = "";
    string $curHotkeySet = `hotkeySet -q -current`;
    if ($enable)
        if ($curHotkeySet == "My_Hotkeys")
            warning("My Product: Nested hotkey settings detected. Please contact support.");
            return;
        $gOrigHotkeySet = $curHotkeySet;
        if (!`hotkeySet -q -exists My_Hotkeys`)
            hotkeySet -current My_Hotkeys;
            nameCommand -ann "Key pressed" -c "myCmd on" myBeginCmd;
            nameCommand -ann "Key released" -c "myCmd off" myEndCmd;
            hotkey -k b -n myBeginCmd -rn myEndCmd;
        else
            hotkeySet -e -current My_Hotkeys;
    else
        if ($gOrigHotkeySet == "My_Hotkeys")
            hotkeySet -e -current "Maya_Default";
        else if ($curHotkeySet == "My_Hotkeys")
            if ($gOrigHotkeySet == "")
            else
                hotkeySet -e -current $gOrigHotkeySet;
    if ($enable)
            return;
        else
    else
            else
stuzzz
stuzzz
Thanks a lot!
I've seen that QuadDraw use the TAB shortcut. I feel like they use Qt framework for that.
They might another solution beside the QApp::installEventFilter, the QAction::setShortcut seems to be a good alternative also.
Thanks a lot!
