Does anyone know the math that Maya performs to derive the orientation offset when constraining one object to another? I'd like to be able to implement this math as Python code so that I can derive the orientation (or even translation) offset myself.
Solved by saihtam. Go to Solution.
Have a look at the videos in the playlist. They cover matrix math (which is what a constraint, and all transforms in Maya/CG uses) and how to do the math for an constraint and Python code.
https://www.youtube.com/watch?v=OlqzCaYSqfg&list=PLoOUA5s0du1Gq9ku-75xfFUqZrmfAgGXu&index=11
In case anyone is interested, I was able to obtain the offset values by using the following code. Thanks to @saihtam for pointing me towards those videos which helped make more sense out of matrix math.
import maya.api.OpenMaya as om
import pymel.core as pm
offset_node = pm.PyNode('offset_node') # this is the node that we want offset values from
target_node = pm.PyNode('target_node') # this is the node that we are measuring against
# get the product of the first object's world matrix and the second object's world inverse matrix
offset_matrix = offset_node.worldMatrix[0].get() * target_node.worldInverseMatrix[0].get()
# convert the matrix to an OpenMaya.MMatrix object
mm = om.MMatrix(offset_matrix)
# convert the MMatrix object to a MTransformationMatrix
mt = om.MTransformationMatrix(mm)
# collect the offset values
rotation_offset = [om.MAngle(x).asDegrees() for x in mt.rotation()]
translation_offset = mt.translation(om.MSpace.kWorld)
scale_offset = mt.scale(om.MSpace.kWorld)
shear_offset = mt.shear(om.MSpace.kWorld)
Great work figuring it out!
Here is some more code depending on what people want to use. Personally I'm not a huge PyMel user and don't think it's worth using just for getting a matrix here. You could instead use xform like this:
import maya.api.OpenMaya as om2
offset_node_wm = om2.MMatrix(cmds.xform('offset_node', q=True, m=True, ws=True))
target_node_wm = om2.MMatrix(cmds.xform('target_node', q=True, m=True, ws=True))
offset_matrix = offset_node_wm * target_node_wm.inverse()
mt = om2.MTransformationMatrix(offset_matrix)
rotation_offset = [om2.MAngle(x).asDegrees() for x in mt.rotation()]
Another thing you could do is skip the OpenMaya all together. In Maya 2019 it seems AD added a new function called "matrixUtil", which allows you to decompose a matrix. You can use it like the below code. Note that I had to include the math library as the rotation is returning radians and not degrees.
import math
translation_offset = cmds.matrixUtil(*offset_matrix, q=True, t=True)
rotation_offset = [math.degrees(x) for x in cmds.matrixUtil(*offset_matrix, q=True, r=True)]
scale_offset = cmds.matrixUtil(*offset_matrix, q=True, s=True)
shear_offset = cmds.matrixUtil(*offset_matrix, q=True, sh=True)
