Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
C++ adding attributes in "Extra Attributes"
1 REPLY 1
MikeSSSS
556 Views, 1 Reply
MikeSSSS
I have figured out how to add attributes using mel with addAttr and setAttr on a particular object, but I am struggling to do so with C++.
With C++, I want to ideally add an attribute to an object dynamically when my plugin starts, and then propogate those attributes to other objects.
The pieces I am playing around with are below--I just want to know if I am on the right track as far as doing this with the C++ api.
MFnNumericAttribute attr;
MGlobal::executeCommand("select MyParentObject;");
MObject newAttr = attr.create("testAttribute", "t", MFnNumericData::kDouble, 0.0);
	MDagPath node;
	MObject component;
	MSelectionList list;
	MFnDagNode nodeFn;
	MPxNode n;
	n.addAttribute(newAttr);
	// From our selection list
	MGlobal::getActiveSelectionList(list);
	for (unsigned int index = 0; index < list.length(); index++){
		list.getDagPath(index, node, component);
		nodeFn.setObject(node);
		nodeFn.addChild(newAttr);
		MStatus stat = nodeFn.addAttribute(newAttr);
		if (MS::kSuccess != stat) {
			MGlobal::displayInfo("Failed to add attribute");
		MGlobal::displayInfo(nodeFn.name().asChar());
		MGlobal::displayInfo(" is selected");
	MDagPath node;
	MObject component;
	MFnDagNode nodeFn;
	MPxNode n;
1 REPLY 1
MikeSSSS
in reply to: MikeSSSS
MikeSSSS
Was able to 'sort of' find a solution on Maya 2020:
Made a static class, then was able to add a callback function.
s_callbackID = MNodeMessage::addAttributeChangedCallback(node, userCB, NULL, &stat);
It doesn't seem to register unless I add it twice however, which is likely going to cause problems elsewhere.
Anyone else have issues or solutions with this?
