Maya Programming
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya SDK topics.
Anyone get this invalid syntax issue when using Python 3 of Maya 2022?
24 REPLIES 24
Message 1 of 25
Hai__Nguyen
43778 Views, 24 Replies
I got a tool I developed myself, which is still used okay in 2019 version of Maya. But when I updated to 2022 version, suddenly I couldn't use it anymore, the script editor said:
# Error: SyntaxError: file C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py line 142: invalid syntax #
I designed it in a class way and called it like this in the Python tab:
import scenePublisher; reload(scenePublisher)
sc = scenePublisher.ScenePublisher(windowID = 'ScenePublisher', title = 'Scene Publisher', codec = 'film')
Anybody experienced this or know what this is I'll be really thankful!
24 REPLIES 24
Message 2 of 25
zewt
in reply to: Hai__Nguyen
Do you have the whole stack trace?  The error probably has nothing to do with shiboken and there should be other lines in the stack trace.  shiboken does nasty things to Python's import and shows up in every import stack trace now.
"reload" isn't a builtin in Python 3, so you need to manually import it (from importlib import reload), but that wouldn't cause a syntax error.
Message 3 of 25
Hai__Nguyen
in reply to: zewt
This is everything I had when I ran the calling code and then the error shown up. Not sure if it's what you need 😕
Message 4 of 25
zewt
Make sure you have History > Show Stack Trace enabled in the script editor.
Message 5 of 25
Hai__Nguyen
in reply to: zewt
Oooooooh I didn't see that coming! It said that it couldn't call the print function I wrote, because I wrote it as print b. This worked normally in Python 2.7 I guess because I did it all the time and it still worked. But as I learnt about Python 3.5 earlier, we gotta write it as print(b),  add in the parentheses. Thanks man!!!
Message 6 of 25
I have the exact same error code but I don't understand the solution here? (I don't understand scripting) I'm following a well-known tutorial from someone who is competent, if you can explain it simply I'd really appreciate it.
Message 7 of 25
Hai__Nguyen
Well it's caused by the syntax is different between 2 Python versions, 2.7 and 3.5. So technically what you can do for now is going to Maya script folder , which is normally inside your document folder, go to script and aim for the python file of the tool which you're currently having the issue. You can open it with any note programs like Notepad or Notepad++ (though Notepad++ will require you to install it, Notepad in the other hand is built in with Windows). Hit Ctrl-F and search for the word "print". You'll need to replace all those "print something" lines to "print(something)" (something is in a pair of parenthesis). Ctrl-S to save it and restart Maya.
Message 8 of 25
I seem to be getting a variation of this for a few different modules:
# Error: No module named 'urllib2'
# Traceback (most recent call last):
# File "<maya console>", line 13, in <module>
# File "C:\Program Files\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
# return original_import(name, *args, **kwargs)
# ModuleNotFoundError: No module named 'urllib2' #
and when trying to simply run:
import pymel.core as pmc
# Error: No module named 'pymel'
# File "<maya console>", line 1, in <module>
# ModuleNotFoundError: No module named 'pymel' #
Any thoughts?
Message 9 of 25
zewt
It's not related, you're just seeing "shiboken" because of some nasty code that a QT library is doing.  Turn on History > Show Stack Trace to see where the errors are actually coming from.
urllib2 doesn't exist in Python 3 since it's been merged into urllib.  You're probably using a plugin that hasn't been updated yet, but I can't tell which without a full stack trace.  It's probably something you need to ask the developer about.
Make sure that you installed PyMEL when you installed Maya 2022.  For some reason there's a checkbox to disable it and it downloads it instead of just installing it like it used to.  (Don't ask me why...)  You can also run this to install it manually instead of reinstalling:
"C:\Program Files\Autodesk\Maya2022\bin\mayapy.exe" -m pip install --user pymel
Message 10 of 25
the_michael_davies
in reply to: zewt
Weird... it seems it must have been disabled then. Running that line activated it, but then disabled Maya from launching, which required a quick re-install. All good now! Thank you!
Message 11 of 25
Can someone explain a bit in an easier way what is going on here? I'm taking python classes at the moment, but I'm not quite ready to understand this type of problem. Although I really like reading about more complex problems and understanding the answer, it makes me feel smarter than I actually am at the moment. It's a change of career for me, and I'll be honest, it was influenced by watching my boys take classes of python coding for kids, it made me realize that maybe there could be something for me as well.
Message 12 of 25
odiusg
Having the same issue. Shiboken2 is causing some interference in some way. The script editor just has this in its bottom dialog:
And it generates this error
# File "D:\Autodesk\Maya2022\Python37\lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
Message 13 of 25
zewt
in reply to: odiusg
That's not related to shiboken (though a shiboken bug is causing it to appear in the error message), it's because you don't have PyMEL installed.
Did you uncheck PyMEL in the installer while installing Maya?
Message 14 of 25
gmdaniel3d
in reply to: zewt
Good afternoon, my name is Daniel. I have the same problem that the title of this thread mentions, however in my case the problem is not the print (""),
in my case it does not recognize the module that is in the project. However if I run it in Maya2020 (python2.7) it works without problem. The error it shows me is something with the shiboken2.
Please, if anyone can help me I will be eternally grateful.
* I prepared a video so that you can understand me,
excuse me that I do not speak English.
Thank you very much to all.
Message 15 of 25
If anyone still suffering with this issue then try this!
https://matiascodesal.com/blog/how-to-launch-maya-2022-with-python-2-if-you-are-not-ready-for-python...
Try Option 1!
Hope it works!
Message 16 of 25
in reply to: roklywangQ5XVV
Thank you. It works
Message 17 of 25
TimSiberia
Awesome. Thank a lot!
Message 18 of 25
This works like a charm, Thank You  😊
Message 19 of 25
Hey,
Your link is dead, does i have just to copy those lines in the shortcut tab ?
ty
Message 20 of 25
Hans_Redman
in reply to: gmdaniel3d
