xyz coordinated from a point cloud to a particle system
I am looking to create a particle system using the xyz coordinates from a point cloud. I've heard I should use a MEL script, but I'm a bit new to MEL. Does anyone have any advice on other methods?
cheng_xi_li
Autodesk Support
Autodesk Support
I am afraid MEL is the best way to do that.
Yours,
Li
joostkonemann
Another possibility is to use partIO, which is a tool developed by Walt Disney Animation Studios to convert between various particle file formats. In the past I used it to convert simple xyz ASCII data to a Maya legacy particle cache. Through a goal, you can drive nParticles from a legacy particle system which is run from the cache.
You'll probably need to compile the tools yourself as I don't think a binary is available.
Link to partIO website: https://www.disneyanimation.com/technology/partio.html
MacBook Pro 13,3 - 2.7GHz - 16GB - Radeon Pro 460 - macOS Catalina 10.15
