xGen query&set description map-attribute
asi.sudai
asi.sudai
Is there a way to query (and also set) the value of a description map attribute?
To be specific, I want to query the "Custom Shader Parameter"
In this case, I would love to get the full attribute value of a fur_root_color.
# Query attribute like this, doesn't work for the map attributes.
import xgenm
xgenm.getAttr('attribute_name','collection_name', 'description_name')
cheng_xi_li
Autodesk Support
Autodesk Support
I've got two samples for setAttr, getAttr should be same.
There are two different conditions.
For the global expression tab.
import xgenm as xg
import xgenm.xgGlobal as xgg
#Add attribute and expandable tab
de = xgg.DescriptionEditor
attr = "custom_" + "color" + "_" + "hairColor"
key = "collection1 " + attr
xg.addCustomAttr(attr, 'collection1')
de.addAttrExprsLayout(attr, True)
#Update with custom expression
myExpression = """
$freq_fine = 0.200; #0.00,1.00
$freq_coarse = 1.000; # 0,100
$X = 1.000; #0.00,10.00
$Y = 1; #0.00,10.00
$Z = 1; #0.00,10.00
$frequency = ($freq_fine+$freq_coarse) * [$X,$Y,$Z];
$Strength=1.000;
$Contrast = 0.962;
$Color = 0.000; #0,1
$Cnew = choose($Color, noise($P*$frequency), cnoise($P*$frequency))
-> contrast($Contrast);
mix($Cs,$Cnew,$Strength)
#Attr is stored in the palette, check xgDescriptionEditor.getAttr for more details about how to access Description/Palette object
xg.setAttr('custom_color_hairColor', xg.prepForAttribute(myExpression), "collection1", "",'Palette')
#Refresh
de.refresh("Full")
For stored in preview/expression tab
import xgenm as xg
import maya.cmds as cmds
cmds.file(new=True, force=True)
cmds.polySphere()
PALETTE = "collection1"
DESCRIPTION = "description1";
PRIMITIVE = "Spline";
GENERATOR = "Random";
RENDERER = "Renderman";
METHOD = "Guides";
GROOMING = False
res = xg.createBindDescription( PALETTE, DESCRIPTION, PRIMITIVE, GENERATOR, RENDERER , METHOD, GROOMING)
#RenderAPIObject k_RenderAPIRenderer = "Renderman" k_RenderAPIRendererObj = k_RenderAPIRenderer + "Renderer" #From noiseE expression in library myExpression = """ $freq_fine = 0.200; #0.00,1.00 $freq_coarse = 1.000; # 0,100 $X = 1.000; #0.00,10.00 $Y = 1; #0.00,10.00 $Z = 1; #0.00,10.00 $frequency = ($freq_fine+$freq_coarse) * [$X,$Y,$Z]; $Strength=1.000; $Contrast = 0.962; $Color = 0.000; #0,1 $Cnew = choose($Color, noise($P*$frequency), cnoise($P*$frequency)) -> contrast($Contrast); mix($Cs,$Cnew,$Strength) """ de = xgg.DescriptionEditor #please follow the attribute naming format, custom_%typeindroplist%_%attributename% xg.addCustomAttr('custom_color_hairColor', de.currentPalette(), de.currentDescription(), k_RenderAPIRendererObj) xg.setAttr('custom_color_hairColor', xg.prepForAttribute(myExpression), "collection1", "description1", k_RenderAPIRendererObj) de.refresh("Full")
Yours,
Li
