Where do you download Maya debug symbols?
barnabas79
barnabas79
Hi - I wanted to check to see if the debug symbols for maya-2019 were available yet, but it seems I can't even find the correct place to login + download from anymore.  I am an ADN (and ADN-sparks, if that's still a thing) member, and logged into the ADN sparks website, but the website / login seems to have changed in a way that I can't find where to download the debug symbols from.
To be more exact: I went to this website:
https://www.autodesk.com/developer-network/overview#
...and first tried to click on the "Member Login" "menubar item" on the far right (to the right of "Certified Apps").  That led me to an error page (https://adn.autodesk.io/, which errors with HTTP Error 503 - "The adn.autodesk.io page isn't working".  So I then tried clicking on the "Sign In" item at the very top (just to the right of the search bar), and that seemed to work / accept my login... but just left me at the same page, and I couldn't find any links to download debug symbols anywhere.
I seem to remember that used to be able to log in the ADN website, and get taken to a different area from which I could download the debug symbols.  Thanks in advance!
- Paul
barnabas79
Just in case anyone searches and sees this - a helpful autodesk support person reached out to me, and the problem was that the correct website was down - https://adn.autodesk.io/.  It's back up again now, so you you should be able to go there to download your debug symbols (assuming you're an ADN member.)
This is the link that you would get to by clicking on the "Member Login" "menubar item" on the far right (to the right of "Certified Apps") from https://www.autodesk.com/developer-network/overview#.
Do NOT click on the  "Sign In" item at the very top (just to the right of the search bar), as this will not take you to the correct site where you can download debug symbols.
Thanks!
Even with the suggestions it still took a bit of searching to actually find the symbols.
* the search function doesn't seem to find anything when searching for "debug symbols"
Here are the steps I followed:
1.  Go to this page: https://www.autodesk.com/developer-network/overview#
2.  As suggested: Click the "Members Login" text on the far right of the screen. Next to the "Certified Apps"
3. Once logged in with your credentials you should end up on this page: https://adn.autodesk.io if not click the link.
4. Go to "Software->Media & Entertainment Special Download"
5. Select Autodesk Maya
6. Select your version number
7. Here you can find the devkits and debug symbols.
Hope it helps.
