What can cause this plugin problem?
When i try to export a model using my plugin i get this error (im using maya 8.5):
// Error: Unable to dynamically load : C:/Program Files/Call of Duty Modern Warfare/bin/maya/tools/XModelExport.mll
// Error: //
// Error: (XModelExport) //
// Error: XModelExport plugin is not loaded //
Can u guys help me about this problem? 😕
I have had this similar problem before.
The problem was for me that the plugin is requiring some other DLL file. -- -- I had to put these dll files inside Maya's bin folder and it worked fine.
For example, my Plugin was using part of glew32.lib  -- so I had to put the glew32.dll inside of Maya's Bin -- and it worked fine.
It could also be that the System does not have an installed dll in System32 or such.
