viewRenderOverrideFromFragments API 2.0 SystemError
I was trying to load viewRenderOverrideFromFragments example plugin from devkit but after loading it returns the following error
"SystemError: error return without exception set" on line 157 of the example code.
Here is the source code from
http://help.autodesk.com/view/MAYAUL/2018/ENU//?guid=__py_ref_view_render_override_from_fragments_2p...
It errors out on line 157: 'params = self.getParameters()' - getParameters() is a function of MScenerRender
I did update plugin initialization path in the code. So just wondering am I doing something wrong while loading this plugin? or is this a bug within maya's internal getParameters() function code? I am assuming this is coming from python interpretation of C++.
Is there a way to get around with this problem? Any advice is greatly appreciated.
Thanks!
cheng_xi_li
Autodesk Support
Autodesk Support
In pyGroundReflectionRenderer.py line 242, please add your plugin's path like below:
    pathToPlugin = 'E:/viewRenderOverrideFromFragments/'
Yours,
Li
Hi Cheng,
I did add the path correctly in line 242 and plugin loaded successfully. The above-mentioned error is returned when I switch to a new viewRenderOverride viewport.
For example, try running the below code in script editor:
import maya.api.OpenMaya as om
import maya.api.OpenMayaRender as omr
fsr = omr.MSceneRender('fr').getParameters()
Gives a SystemError on line 3, I assume it should return a python swig object but it returns an error when getParameters() function is called.
By any chance did it work for you after loading the plugin?
Thanks a lot!
cheng_xi_li
Autodesk Support
Autodesk Support
After I set path to it
def initializePlugin(mobject):
    # NOTICE:  Please set the path to the plugin before running
It worked. I've tested it before reply to you.
fsr = omr.MSceneRender('fr').getParameters() won't work because shaderFragment is missing in the renderer.
Add a shader fragment fsr = omr.MSceneRender('fr','mayaChecker').getParameters() will work.
So the issue for that sample is plug-in failed to add shaderfragment. I guess path is still incorrect in your source code or shaders' folder and files are missing in the plugin path .
Yours,
Li
Hi Li,
Thank you very much for clarifying it and I really appreciate it! You were correct that there was something wrong with my path initialization.
I changed it accordingly and now it works for me.
Shashank
