Using Pandas inside Maya python shell
jeremyraven
jeremyraven
Im trying to setup the python environment so that I can import the pandas framework.
I installed pandas using Anaconda that has installed pandas at ".opt/anaconda3/lib/python3.8/site-packages"
so inside a python shell in Maya Ive written this code...
import sys
sys.path.append (".opt/anaconda3/lib/python3.8/site-packages")
import pandas
but  Im getting this message:
# Error: ImportError: file <maya console> line 4: No module named pandas #
I've CD'd into this directory and printed the directory contents out and sure enough pandas is definitely inside there and if I print out the PYTHONPATH ".opt/anaconda3/lib/python3.8/site-packages" is on that list.
Any ideas as to what I can do to fix this?
Many thanks
bradley_henke
Looks like that is the python 3 version of pandas. Maya ships with python 2.7, so you will probably need a different version of pandas, numpy, etc.
I'm also assuming that you probably meant to type "/opt" instead of ".opt". That may be the reason that the module is not being found.
jeremyraven
Thanks Bradley,
you are right, I was using a version of pandas which was not compatible with python 2.7.
Many thanks
183110675Z7WVZ
Community Visitor
Community Visitor
Hello Jeremy, could you please let me know which pandas version you installed?
Thank you in advance.
-Abigail Jimenez
stevejonn
Community Visitor
Community Visitor
In most cases this error in Python generally raised:
  • You haven't installed Pandas explicitly with pip install pandas.
  • You may have different Python versions on your computer and Pandas is not installed for the particular version you're using.
You can run the following command in your Linux/MacOS/Windows terminal.
pip install pandas
To be sure you are not having multiple Python versions that are confusing, you should run following commands:
python3 -m pip install pandas
python3 -c 'import pandas'
