Using OpenGL to draw in a MPxContext?
I am using the Maya API in C++. I would like to do something very simple, but I cannot manage to make it work: draw a line in Maya, using openGL.
In my class "MyClass", which inheritate from "MPxContext", I redefine the function "doDrag". And I would like to draw a line in this function.
A version that works is the following one:
MStatus MyClass::doDrag(MEvent &event, MHWRender::MUIDrawManager &drawMgr, const MHWRender::MFrameContext& context)
        MColor red(1.0f, 0.0f, 0.0f);
        drawMgr.beginDrawable();
        drawMgr.setColor(red);
        drawMgr.line(MPoint(0, 0, 0), MPoint(10, 10, 10));
        drawMgr.endDrawable();
         return MS::kSuccess;
But I would like to use OpenGL instead, because later I will have to do more complicated stuff. So if something like that would work, it would be great:
        glBegin(GL_LINES);
        glColor3f(1.0f, 0.0f, 0.0f);
        glVertex3d(0.0, 0.0, 0.0);
        glVertex3d(10.0, 10.0, 10.0);
        glEnd();
Does anyone has an idea how to do that? I spent hours searching a solution on the web, I really need your help.
Thanks a lot.
cheng_xi_li
Autodesk Support
Autodesk Support
Hi loic,
I am afraid you can't do that in VP2 MPxContext. MUIDrawManager must be used for any viewport drawing done in this method. Direct calls to OpenGL or DirectX are unsupported and may result in instability or unpredictable behavior.
Yours,
Li
Hi Li,
Thank you for your answer. It is really too bad that it is not possible to do that in VP2...
Is there a solution to draw with OpenGL in another viewport (Legacy viewport)?
Best,
Loic
cheng_xi_li
Autodesk Support
Autodesk Support
Hi loic,
Yes, you can use OpenGL in legacy viewport.
MPxContext::doDrag (MEvent &event) is called in legacy viewport. You can use OpenGL to draw items in function above.  The helixTool sample in our devkit is one of the samples for using OpenGL in Legacy Viewport to create an interactive tool.
Yours,
Li
Okay.
Thank you for your help Li!
Best.
