Switch proxy by modifying the scene file?
Message 1 of 1
I have a scene file with proxies for low, medium, and high resolution geometry.  If I have Maya launched, I can switch a proxy by right clicking a reference in the Reference Editor and going to Proxy -> Reload Proxy As.  I can also use the proxySwitch mel command.
Can you switch proxies without even opening Maya?  Basically, I want to know if I can hack the .ma file and set the proxies that way.  My issue is that the scene file has a lot of objects.  If I load in the high resolution proxies (for rendering), the process takes forever and crashes Maya 2016.  I have taken a look at the scene file and it is not readily apparent to me how to do this.
Replies (0)
