Unable to call MPxDeformerNode.weightValue in method defined outside class
jmreinhart
Advisor Advisor
Message 1 of 10
jmreinhart
So I am making a custom deformer using the MPxDeformerNode class. When I define the "deform" method inside of the class I am able to call weightValue(...) without issue, but when I declare the method inside the class and then define it outside the class calling weightValue causes a linker error. I tested this by removing everything but the weightValue query from the deform method so I know that this is the issue.
Error LNK2019 unresolved external symbol "__declspec(dllimport) public: float __cdecl Autodesk::Maya::OpenMaya20180000::MPxDeformerNode::weightValue(class Autodesk::Maya::OpenMaya20180000::MDataBlock &,unsigned int,unsigned int)" (__imp_?weightValue@MPxDeformerNode@OpenMaya20180000@Maya@Autodesk@@QEAAMAEAVMDataBlock@234@II@Z) referenced in function "public: virtual class Autodesk::Maya::OpenMaya20180000::MStatus __cdecl offset::deform(class Autodesk::Maya::OpenMaya20180000::MDataBlock &,class Autodesk::Maya::OpenMaya20180000::MItGeometry &,class Autodesk::Maya::OpenMaya20180000::MMatrix const &,unsigned int)" (?deform@offset@@UEAA?
I've looked at some example deformers and they are able to call it in a function defined outside the class.
I was able to find a forum post that seemed to be related to this same issue but the response to that post was "use cmake".
Replies (9)
Message 2 of 10
olarn
How about just  rewrite the original in-class weightValue so that it calls your external function.
Message 3 of 10
jmreinhart
Sorry I don't think I did a good job of explaining the problem I'm running into. The below code is what gives me a linker error.
class offset : public MPxDeformerNode
public:
	offset();
	virtual                         ~offset();
	static  void*           creator() { return new offset(); };
	static  MStatus         initialize() {};
	// deformation function
	virtual MStatus deform(MDataBlock&              block,
		MItGeometry&         iter,
		const MMatrix&       mat,
		unsigned int         multiIndex);
private:
MStatus offset::deform(MDataBlock& block, MItGeometry& iter, const MMatrix& mat, unsigned int multiIndex)
	float x = weightValue(block, multiIndex, iter.index());
	return MS::kSuccess;
But this code does not give me a linker error
#include <maya/MPxDeformerNode.h>
#include <maya/MItGeometry.h>
#include <maya/MFnMatrixData.h>
#include <maya/MFnPlugin.h>
#include <maya/MTypeId.h>
#include <maya/MDataBlock.h>
#include <maya/MDataHandle.h>
#include <maya/MArrayDataHandle.h>
#include <maya/MMatrix.h>
#include <maya/MDagModifier.h>
#include <maya/MObject.h>
public:
	offset();
	virtual                         ~offset();
	static float weightValue(MDataBlock& block, unsigned int multiIndex, unsigned int compIndex);
private:
I think I'm just not understanding something about inheritance, nut I'm quite new to C++ so I may be wrong.
Message 4 of 10
olarn
Looks like the first example actually compiles.
Did you forget to remove this declaration? unless you intent (and forgot) to implement.
Btw the second example weren't supposed to compile. What compiler were you using?
Message 5 of 10
jmreinhart
Oops I made a mistake when copying those codes, this is the one that DOES compile:
public:
	offset();
	virtual                         ~offset();
	MStatus deform(MDataBlock& block, MItGeometry& iter, const MMatrix& mat, unsigned int multiIndex)
private:
This one that does NOT:
public:
	offset();
	virtual                         ~offset();
		MItGeometry&         iter,
		const MMatrix&       mat,
private:
I am using visual studio 2017 to compile.
Message 6 of 10
jmreinhart
So I did some testing with reimplimenting weightValue inside and outside the class. Both work.
Does this function always need to be re-implimented?
Where in the documentation would I be able to see if it is required to re-impliment a certain method?
This is the setup that worked for me:
#include <maya/MPxNode.h>
public:
	offset();
	virtual                         ~offset();
		MItGeometry&         iter,
		const MMatrix&       mat,
private:
float offset::weightValue(MDataBlock& block, unsigned int multiIndex, unsigned int compIndex)
	return 0;
Message 7 of 10
olarn
I can't replicate your issue. This is the entirety of one file plugin and it compiles (on vs2019, using vs2017 compiler)
const MTypeId TYPE_ID(123456);
public:
  offset() {}
  ~offset() override {}
  static  MStatus         initialize() { return MStatus::kSuccess; }
    MItGeometry& iter,
    const MMatrix& mat,
private:
MStatus initializePlugin(MObject obj) {
 MStatus status = MStatus::kSuccess;
 MFnPlugin plugin(obj, "AAA", "0.0", "Any");
 status = plugin.registerNode("test",
   TYPE_ID,
   offset::creator,
   offset::initialize);
 return status;
MStatus uninitializePlugin(MObject obj) {
 MFnPlugin plugin(obj);
 status = plugin.deregisterNode(TYPE_ID);
 return status;
Message 8 of 10
jmreinhart
When I run the code you posted I get several linker errors. Below is one of them
Error LNK2019 unresolved external symbol "__declspec(dllimport) public: __cdecl Autodesk::Maya::OpenMaya20180000::MPxDeformerNode::MPxDeformerNode(void)" (__imp_??0MPxDeformerNode@OpenMaya20180000@Maya@Autodesk@@QEAA@XZ) referenced in function "public: __cdecl offset::offset(void)" (??0offset@@QEAA@XZ) Project3 C:\Users\Jonah\source\repos\test_node\Project3\test.obj 1
I'm going to delete my OpenMaya lib and re-download it and I guess look at my linker settings, because if it runs for you it must be an issue on my end.
Message 9 of 10
olarn
Perhaps you forgot to add some necessary maya *.lib or not using a matching version?
grap this or one of the forks for easier project setup.
https://github.com/chadmv/cgcmake
Message 10 of 10
jmreinhart
Based on your suggestion I checked the libraries I was bringing in and I had missed OpenMayaAnim.lib. I'm a bit confused as to why MPxNode is in OpenMaya.lib but MPxDefomerNode is an OpenMayaAnim.lib  but oh well.
I really appreciate all your patience and your help.
