Custom duplicate or post duplicate
Sebastian_Wiendl
Sebastian_Wiendl
Hi all,
I am having an issue with the duplicate functionality.
Basically, when certain of my custom nodes are created, they need to be connected to others in a special way that cannot be done via the default duplicate or duplicate special, i.e. if I just duplicate a node, the result is bad because the connections to other nodes are all wrong.
This is why I was wondering if there was a way to override a node's duplicate in c++, or have a post duplicate function.
I tried accessing the node's plugs from c++ in MDGMessage::addNodeAddedCallback and also via the postConstructor function, but it seems that at that stage none of the (wrong) connections have been made yet.
Any help would be much appreciated.
Cheers,
Sebastian
Sebastian_Wiendl
Hi olarn,
Thanks so much for your response.
The issue with this api is that I can't tell what triggered it.
I have scripts, etc that create new nodes and hook them up properly and they would trigger the callbacks as well; not just the duplicate.
In theory, it should be possible to use the api you sent, but it would mean a lot of rework of how I do things currently.
I really would like to avoid that.
Cheers,
Sebastian
Cheers,
Sebastian
olarn
http://help.autodesk.com/cloudhelp/2018/ENU/Maya-SDK/cpp_ref/class_m_px_node.html?_ga=2.110884805.11...
You should return kUnknownParameter to specify that maya should handle this connection or if you want maya to process the connection as well.
I think simply overriding and then returning anything other than kUnknownParameter will probably stop maya from auto connecting everything in default duplicate. This should give your full control
Also all commands in maya are synchronous so in theory you can keep stack of history somewhere static and then pop it when that api gets called and that should tell where it's coming from
Sebastian_Wiendl
Hi olarn,
Thanks so much for getting back to me again.
I will experiement some more.
Your answer is the best possible solution I could find.
Much appreciated.
Cheers,
Sebastian
