tweenMachine.mel won't run because of source statement?
Hey everyone,
I hope you are all doing well. I have a question about running tweenMachine as downloaded from Github. I was able to put the .mel file in the script folder for Maya 2020, however it will not run due to a strange error. Let me show you a picture of what I am talking about:
So, I put the .mel file in the general script folder for all my Maya versions but I also put the .mel file in the version specific folder in Maya 2020 and Maya 2022.
BigRoy
You'd need to copy the xml_lib.mel file to your scripts folder too: https://github.com/boredstiff/tweenMachine/tree/master/mel
However even better is using the Python version. Because as the README states the Mel version is no longer supported.
Okay, thank you I will test this out. Are their specific tutorials for the Python versions that you recommend? Thank you very much
Also are you saying that MEL versions can't work at all? I tried running it again but it doesn't seem to work on Maya 2020
BigRoy
So the MEL version does work in Maya 2020 - I quickly checked here.
I copied both these files https://github.com/boredstiff/tweenMachine/tree/master/mel to my scripts folder for Maya 2020. Restarted maya and ran the following code in MEL Script Editor to run it:
tweenMachine;
However, even though it does work I'd recommend using the more updated version, which is the Python version.
To use that copy over the script files in https://github.com/boredstiff/tweenMachine/tree/master/python to your scripts folder.
Then in Maya in Script Editor in a Python Tab you can import that python module and run the right command. According to the documentation in the code repository it's INCORRECTLY shown as this:
import tweenMachine
tweenMachine.start()
 This won't work because the Python file is called "tween_machine.py".
The right command to call is thus:
import tween_machine
tween_machine.start()
Note that this particular TweenMachine library has been abandoned and looking for new code maintainers. Some forks do have updates, e.g. to Python 3 compatibility to potentially work with Maya 2022+ but it's not in this particular github repository. For example: https://github.com/boredstiff/tweenMachine/pull/35
Anyway, hope that helps.
I tried exactly the same steps from the first section, tween still doesn't run at all. My oriignal steps were the following:
Maya 2020
1. rehash; Highlight+Enter
2.Oddly enough the word disappears
3. Go to Open Source and run tweenMachine.mel file.
4. Nothing happens
Same thing occurs with Maya 2022
I used the same line of code and it just disappears after I try to run it.
