Announcements
Trouble with changing front & rear view port via script
Hey i don't know if a similar post like this is already up but i nee to figure out why this script isn't working out. I tried using a script to change the view ports when i select either the front or the rear to the opposite but when ever i run the script in the editor i keep getting this error message. Can anyone tell me what i am doing wrong ?
if(('modelPanel -q -cam modelPanel13')=="rear")
modelPanel -e -cam front modelPanel13;
setAttr front.visibility 1;
setAttr rear.visibility 0;
else
modelPanel -e -cam rear modelPanel13;
setAttr front.visibility 0;
setAttr rear.visibility 1;
Here is the error message i receive.
editMenuUpdate MayaWindow|mainEditMenu;
else
// Error: if(('modelPanel -q -cam modelPanel13')=="rear")
// Error: Syntax error //
// Error: }
// Error: }; //
You're using single quotes ' in stead of backquotes `
if((`modelPanel -q -cam modelPanel4`)=="rear")
Thank you
