Announcements
New to MEL trying to write export plugin
I'm writing an export plugin to write mesh data to a file and just need a push in the right direction.
I'm finding MEL easy to use, I'm just not sure what call to make that will allow me to query all the different polygon (mesh) objects so that I might get the vert, normal, uv and material data from each object.
I think I read somewhere that you get to this stuff via nodes? Any help would be appreciated.
haggi
Using mel is not the best approach. You are much more flexible and efficient using python. And to write an exporter, you can access mayas internal data via API calls.
In the maya devkit directory you can find an python exporter example.
Thanks, I'll do that. Wasn't sure which way to go, MEL or Python.
