The specified module could not be found
egoldid1
egoldid1
 hi!
I wrote a deformer node with c++ (build the solution in Visual Studio 2015)....
It Properly works on my system(maya 2018, window 7) but on some system it does not.
 error message:
"(The specified module could not be found)"
cheng_xi_li
Autodesk Support
Autodesk Support
It sounds like missing certain dlls. Could you check it with dependency walker?
I guess you are building with debug configuration and most of the time debug version of vc runtime couldn't be found on non-developer computers. If it's the issue, switching to release configuration could solve this issue.
Yours,
Li
