Take Direction (rotation)
lobo_alcalino
lobo_alcalino
Hi there!
Is there a way (node) that I can use in order to act like a trigger depending on the rotation of an object in relation to the World? (I'm sorry if the question is too dumb).
e.g.: If object is facing -Y, then...
jmreinhart
Not a dumb question, just a little vague but I think I get what you're asking.  I've attached a scene file example.
I use a vectorProduct node to get the direction the objects X axis is pointing in worldSpace. Then I'm getting the angle between than vector and the global +Y vector. If the angle is less than 90 then the object is pointing up, if not then it is pointing down.
