Syntax Error with UV tiling mode
connor7270
Observer Observer
connor7270
Observer
Observer
Hello all!
I have run into a problem with the file [texture] node where attempting to define a UV tiling mode (such as Mari) results in a syntax error from the AEfiletemplate MEL script. I have tried reseting my preferences, reinstalling, and using a different version of maya, but the issue is persistent. I normally use 2020.4, but the issue is the same using 2022.
setAttr "file1.uvTilingMode" 3;
# Error: file: F:/Programs/Maya_2020/Maya2020/scripts/AETemplates/AEfileTemplate.mel line 104: invalid syntax #
# Error: file: F:/Programs/Maya_2020/Maya2020/scripts/AETemplates/AEfileTemplate.mel line 39: invalid syntax #
# Error: file: F:/Programs/Maya_2020/Maya2020/scripts/AETemplates/AEfileTemplate.mel line 154: invalid syntax #
# Error: file: F:/Programs/Maya_2020/Maya2020/scripts/AETemplates/AEfileTemplate.mel line 668: invalid syntax #
# Error: invalid syntax #
airelav_83
Observer
Observer
Hello, I got the same problem! did you find a solution?
