sweepMeshFromCurve
sweepMeshFromCurve
robertofernadez2492
sweepMeshFromCurve
robertofernadez2492
Is there any way to get the nodes creates by sweepMeshCreator in MEL?
I know that there is an sweepMeshCreator.outMeshArray attribute, but if i try to get its value i get
Error: line 1: The attribute is compound with mixed type elements.
thankx
Roberto
Kahylan
Hi!
compound attributes like this are basically coded shape nodes which have a to of different attributes and math in them so getAttr doesn't give any results because they would not be understandable to a human. But what you can do is look for the outgoing connections of your sweepMeshCreator node and filter them by object type "mesh" and you will get all the objects created by the sweepMeshCreator node.
Here is an example of how you can get  and print the shapes created by all the sweepMeshCreator nodes in the scene:
string $sMC[] = `ls -type "sweepMeshCreator"`;
for ($s in $sMC){
    string $conn[] = `listConnections -t "mesh" -sh true $s`;
    print $conn;
If you want to do it for just a specific sweepMeshCreator node, you can change the first line. Also if you want the transforms of the sweepmeshes instead of the shapes, just change the -sh flag in line 3 to false.
I hope it helps!
robertofernadez2492
thankx a lot, it works for me
Roberto
