standalone.initialize() QT error
jEchoes
jEchoes
I'm trying to run some processes without opening maya. I'm getting kicked out of mayapy when I initialize maya.standalone. It prints out some errors/warnings about Qt and then leaves mayapy. Im not sure if something else is erroring and the QT messages are just warnings. Any help would be appreciated. Everything I have read doesn't encounter this problem.
In command prompt or PowerShell I ran the following
mayapy
That opens the mayapy prompt. Then I ran these lines:
import maya.standalone as standalone
standalone.initialize(name='python')
Error message:
Qt WebEngine seems to be initialized from a plugin. Please set Qt::AA_ShareOpenGLContexts using QCoreApplication::setAttribute before constructing QGuiApplication. qt.svg: Cannot open file ':/expression.svg', because: No such file or directory qt.svg: Cannot open file ':/expression.svg', because: No such file or directory QWidget: Cannot create a QWidget without QApplication
From here I expect it to stay in mayapy so I can run some python.
Maya 2023.0
Windows 11
lee.dunham
It sounds like a plugin using autoload requires the QtWebEngine.
If you disable all of them and try again, do you get the same issue?
