spacing in UI
spacing in UI
5rivamsi
spacing in UI
5rivamsi
I'm tring to use cs=[int,int] for rowColumnLayout but couldn't understand how to use it to set space between all coloumns evenly. it's only working for one column. but "rs" flag seem to work for all rows. what am I missing? Also, I need help spacing checkboxes from checkBoxGrp().
thanks in advance
Kahylan
Hi!
If you want to space out colums you'll need to feed the cs flag in the following way:
#One specified space
cs = [numberOfColumn,Spacing]
#Multiple specified spaces
cs = [[numberOfColumn,Spacing],[numberOfColumn,Spacing],[numberOfColumn,Spacing],[numberOfColumn,Spacing]]
so in an example with a rowColumLayout that has 3 columns that you want to be spaced by 400 pixels:
import maya.cmds as cmds
cmds.rowColumnLayout( numberOfColumns=3, cs = [[1,400],[2,400],[3,400]])
Now, this gives you the ability to do custom spacings for each column, but sadly as far as I know there isn't a way to just have the columns spaced out evenly without feeding a value for each one.
I hoep it helps!
