setKeyframe at a time, and force re-evaluation?
- Mute
- Permalink
- Report
I use "setKeyframe" to set the "translateX" value at a given time. Immediately afterwards, I query the "translateX" value and "matrix" value at that time. The "translateX" returns the correct value, but the "matrix" does not.
Here is my sample code:
def setValueAtTime(value, time):
node = 'pCube1' cmds.setKeyframe(node, attribute='translateX', time=time, value=value) xValAfter = cmds.getAttr(node+'.translateX', time=time) matAfter = cmds.getAttr(node+'.matrix', time=time) print 'new translateX: {0}\t\t new matrix[12]: {1}'.format(xValAfter, matAfter[12])
for i in range(3):
setValueAtTime(i, 5)
Assuming the cube starts out with an x-translation of 2.0, it prints out the following result:
new translateX: 0.0 new matrix[12]: 2.0 new translateX: 1.0 new matrix[12]: 2.0 new translateX: 2.0 new matrix[12]: 2.0
The documentation for "setKeyframe" says, "Using the value flag will not cause the keyed attribute to change to the specified value until the scene re-evaluates. Therefore, if you want the attribute to update to the new value immediately, use the setAttr command in addition to setting the key." But "setAttr" doesn't have a time parameter, and I don't want to set the value at the current time. Also, I don't want to re-evaluate the entire scene because it is large and complicated.
Questions:
- What is the best way to force the "matrix" attribute to update, without re-evaluating the entire scene? (I have a couple of hacky workarounds but am hoping there's a better way.)
- Why does "translateX" update to the correct value but "matrix" does not?
