Announcements
setAttr comands for Arnold
Hello, how to find out name that can be used to influence checkerbox under shape node of an object/Arnold/Displacement Attributes/Autobump and there Camera (primarily) . When you click on that checkbox command didn't echoed in script editor. For example Enable Autobump checkbox have name "
aiDispAutobump" so what is the name for the Camera (primarily)?  Or is there way to find those names, some documentation, something? Thanks
mspeer
Hi!
It's "aiAutobumpVisibility".
Try:
setAttr aiDispAutobump.aiAutobumpVisibility true;
e_honda
Hi.
If there is nothing echoed inside Maya, you can check it in the dirty way.
Save your scene in Maya ASCII(.ma) format without the check and save the scene with check as another file.
After that, you can compare those files' text and see what changed between them.
(I'll recommend using some third-party software to help you doing that)
Probably you'll see that some setAttr line is different.
Hope it helps.
