Select attribute.
Select attribute.
dg3duy
Select attribute.
dg3duy
I want to select the attributes with a single click, looking for information I found this code that works but I have to run the script twice to select the attribute, is there a way to select it with only 1 click?
channelBox -edit -select ".Deform_A" mainChannelBox;
Kahylan
Hi!
The script works fine for me.
Does the same happen if you execute this?
channelBox -edit -select ".tx" mainChannelBox;
Can you tell me something more about the attibute? Is it connected to anything? Is there a parent Attriubte?
dg3duy
It works correctly now, the software was crashing. Closing it and opening it again solved it.
