ScriptJob = Frame selection
dg3duy
Message 1 of 8
dg3duy
I am investigating how to select the objects on screen and keep them centered on the screen, the closest I found is this.
With the current option I am using I have to deselect the element and select a new one for the scriptjob to act, I would like it to be activated every time I select an object on the screen.
 I would like to be able to use the SelectionChanged option, but I don't know how to use it.
import maya.cmds as cmds
jobNum = cmds.scriptJob( ct= ["SomethingSelected","cmds.viewFit()"])
#cmds.scriptJob( kill=jobNum, force=True)
(view in My Videos)
Accepted solutions (3)
Replies (7)
Message 2 of 8
Kahylan
Hi!
I have to be honest, I think the constant view jumping would make me throw up if I had this on all the time.
But here is how you do it, have fun:
jobNum = cmds.scriptJob( e = ["SelectionChanged","cmds.viewFit()"])
I hope it helps!
Message 3 of 8
dg3duy
It is excellent!
Message 4 of 8
dg3duy
@Kahylan I forget the idea that it can be done without the on-screen jump, it's a losing battle I'm looking for?
Message 5 of 8
Kahylan
I looked it up and the viewFit command does have a flag for animated transitions.
jobNum = cmds.scriptJob( e = ["SelectionChanged","cmds.viewFit(an = True)"])
 you might also want use the fitfactor or center flag. depending on what you have in mind
https://help.autodesk.com/cloudhelp/2022/ENU/Maya-Tech-Docs/CommandsPython/viewFit.html
Message 6 of 8
dg3duy
@Kahylan
The publication of this post became more and more profound but very didactic.
The noChildren(noc) option I can't get it to work, I didn't manage to apply it.
Surely I am missing something.
cmds.viewFit( 'persp1', noc=True )
Message 7 of 8
Kahylan
The noc flag is True by default, so you don't see any change when setting it True, only when setting it to False
Message 8 of 8
dg3duy
jobNum = cmds.scriptJob( ct = ["SomethingSelected","cmds.viewFit(an = True),cmds.viewFit(c = True),cmds.viewFit( f=0.5 )"]),cmds.scriptJob( e= ["SelectionChanged","cmds.select( clear=True ),cmds.undo()"])
##cmds.scriptJob(kill=jobNum)
I want to show you what I was able to do based on your great help.
