Scriptjob error...
Scriptjob error...
dg3duy
Scriptjob error...
dg3duy
The following code when executed creates an icon and a description, clicking on the icon executes the code. Perfect!!! goes everything up to that moment.
I close Maya and open a new section of Maya, I click on the script icon and I get an error.
it's the first time something like this has happened to me... 😲
# Error: NameError: file <maya console> line 1: name 'createScriptJob' is not defined
the code:
import maya.cmds as mc
import maya.cmds as cmds
import maya.mel as mel
topShelf = mel.eval('$nul = $gShelfTopLevel')
currentShelf = mc.tabLayout(topShelf, q=1, st=1)
# Store the scriptJob ID
job_num = None
def updateGraphEditor():
    # Get the current playback range
    min_time = cmds.playbackOptions(query=True, minTime=True)
    max_time = cmds.playbackOptions(query=True, maxTime=True)
    # Set the playback range in the graph editor
    cmds.animView("graphEditor1GraphEd", edit=True, startTime=min_time, endTime=max_time)
def createScriptJob():
    global job_num
    # Create the scriptJob
    job_num = cmds.scriptJob(event=["playbackRangeChanged", updateGraphEditor])
    print("ScriptJob created with ID: " + str(job_num))
def deleteScriptJob():
    global job_num
    if job_num:
        cmds.scriptJob(kill=job_num)
        print("ScriptJob with ID: " + str(job_num) + " deleted")
        job_num = None
    else:
        print("No scriptJob to delete")
mc.shelfButton(parent=currentShelf, i='commandButton.xpm', c='createScriptJob()', dcc='deleteScriptJob()', iol= "Range")
Kahylan
Hi!
Thats because you define your functions in your main script and then you only call your functions from your button. When Maya opens a new scene or closes and starts up again it automatically deletes all loaded functions form the working memory, so when you use your shelfbutton again it is calling a function that maya doesn't know.
There are two ways to approach this. One is that you have your main script as a second external module and you then first run the import command and after run the function in your script. This is what I would do if you have scripts that are longer than this. It would look something like this:
c= "import myScriptJobScript as msjs \nmsjs.createSciptJob"
The second way to do it, which I did here, is to store the command in a single string. You can use "\n" to write new lines and "\t" to write a tab. Also for strings in your script you use '' instead of "" so it doesn't conflict with the overarching string that you feed your command.
mc.shelfButton("scriptJobButton",parent=currentShelf, i='commandButton.xpm', c= "import maya.cmds as mc \nimport maya.cmds as cmds \nimport maya.mel as mel\njob_num = None\n\ndef updateGraphEditor():\n\t# Get the current playback range\n\tmin_time = cmds.playbackOptions(query=True, minTime=True)\n\tmax_time = cmds.playbackOptions(query=True, maxTime=True)\n\n\t# Set the playback range in the graph editor\n\tcmds.animView('graphEditor1GraphEd', edit=True, startTime=min_time, endTime=max_time)\ndef createScriptJob():\n\tglobal job_num\n\t# Create the scriptJob\n\tjob_num = cmds.scriptJob(event=['playbackRangeChanged', updateGraphEditor])\n\tprint('ScriptJob created with ID: ' + str(job_num))\ncreateScriptJob()", dcc="import maya.cmds as mc \nimport maya.cmds as cmds \nimport maya.mel as mel\ndef deleteScriptJob():\n\tglobal job_num\n\tif job_num:\n\t\tcmds.scriptJob(kill=job_num)\n\t\tprint('ScriptJob with ID: ' + str(job_num) + ' deleted')\n\t\tjob_num = None\n\telse:\n\t\tprint('No scriptJob to delete')\ndeleteScriptJob()", iol= "TEST")
I hope it helps!
dg3duy
@Kahylan Awesome! I went for the second option and it works wonders! a success, thank you very much!
