Script to generate curve from selected objects
johnkeates2865
johnkeates2865
I'm trying to make a MEL script which will generate a curve from selected objects but I'm not having much luck. I get an error saying "Invalid flag" followed by the information I am trying to put into the curve. Also, the variable that has the information keeps including blank data but I'm not sure why.
 Please excuse my odd programming methods as I am an artist really 🙂
Here is my script:
proc makeNurbsCurveFromSelection()
// select -hi;
string $selection[] = `ls -sl`;
string $positions[] ;
spaceLocator -n tempLocator;
int $selectionSize = (size($selection));
matrix $itemPos[100] [3] ;
for ($i = 0 ; $i<$selectionSize ; $i++)
pointConstraint -n "tempConstraint" $selection[$i] tempLocator;
$itemPos [$i] [0]= `getAttr "tempLocator.translateX"`;
$itemPos [$i] [1]= `getAttr "tempLocator.translateY"`;
$itemPos [$i] [2]= `getAttr "tempLocator.translateZ"`;
delete "tempConstraint";
string $crvData[];
for ($i=0 ; $i<(($selectionSize)*4) ; $i++ )
$crvData[$i*4] = "-p";
$crvData[($i*4)+1] = (($itemPos [$i] [0]));
$crvData[($i*4)+2] = (($itemPos [$i] [1]));
$crvData[($i*4)+3] = (($itemPos [$i] [2]));
string $curveDataString = stringArrayToString($crvData," ");
curve -d 3 $curveDataString;
delete tempLocator;
tony.su
Autodesk Support
Autodesk Support
I didn't read your script. For this error you can use "eval curve -d 3 $curveDataString;"
Because $curveDataString is not only one flag, so add eval.
Tony Su
Product Support
rajasekaransurjen
Try This.....
proc rsmakeNurbsCurveFromSelection()
    float $positions1[] ;
    string $curvePpints[], $array[];
    for($i=0;$i<size($selection);$i++)
        $positions1 = `xform -q -ws -rp $selection[$i]`;
        $curvePpints[($i*4)] = "-p";
        $curvePpints[($i*4)+1] = $positions1[0];
        $curvePpints[($i*4)+2] = $positions1[1];
        $curvePpints[($i*4)+3] = $positions1[2];
    string $curveDataString = stringArrayToString($curvePpints," ");
johnkeates2865
Excellent! Thanks! That works well and your code is a hell of a lot more tidy and efficient than mine! I will study it closely.
rajasekaransurjen
you’re welcome.
