Script to display an Attribute in the Channel Box as keyable?
BenediZ
Message 1 of 9
BenediZ
there is a frequent task I have to do:
Always to set the ISO of an camera on "keyable" in the Channel Box, so that I can access that attribute in the channel box.
I tried to script this, but I have no deep knowledge. Please help, how to do it right:
string $Cameras[] = `ls -sl -fl`; // storing the camera
// I have actually to select the shape of the camera, ho to do this?
setAttr $Cameras -k on  vrayCameraPhysicalISO; // this only gives an syntax error. Itried different other possibilities, which also didn't work
The desired attribute is called "MyCameraname.vrayCameraPhysicalISO"
Echo commands gave me this:
PS_moveToKeyable Keyable RenderCam;
setAttr -k on |Group_of_cameras|RenderCam|RenderCam.vrayCameraPhysicalShutterSpeed;
button -e -en 1 KEYABLE_Button; button -e -en 1 NONKEYABLE_Button; textScrollList -e -da KEYABLE_List; textScrollList -e -da DISP_NONKEYABLE_List;
Thanks for help!
Replies (8)
Message 2 of 9
mcw0
WOW, what you posted looked really overwhelming.  To make any attribute keyable in the channel box:
setAttr -e -k 1 -cb 1 ($obj+"."+$attr);
Message 3 of 9
BenediZ
Many thanks @mcw0 , I will test it next time!
Message 4 of 9
BenediZ
Hi, it did not work, because of Error: Illegal operation "+" on data of type string[].
I have tested those first two lines:
string $myCamera[] = `ls -sl`; // storing the camera
print ($myCamera"."+"vrayCameraPhysicalISO");
setAttr -e -k 1 -cb 1 ($myCamera+"."+"vrayCameraPhysicalISO");
There must be another way to get the attribute name "spelled" with MEL.
Thanks for help
Message 5 of 9
brentmc
There are some typos in the script. Also, ls returns a list so you need to pull out the first item which is the error you are getting.
Note: you should also check the size($myCamera) to make sure it is greater than 0 before trying to access the list.
print ($myCamera[0]+".vrayCameraPhysicalISO");
Brent
Brent McPherson
Principle Software Developer
Message 6 of 9
BenediZ
Right, but the typo was only here in the forum. Look here the  result without typo:
print ($myCamera+"."+"vrayCameraPhysicalISO");
// Error: print ($myCamera+"."+"vrayCameraPhysicalISO"); //
// Error: Line 2.21: Illegal operation "+" on data of type string[]. //
Message 7 of 9
brentmc
I updated my original reply.
Some commands like ls return a list so you need to pull out the item you are interested in.
Brent
Brent McPherson
Message 8 of 9
BenediZ
Great, it works:
pickWalkDown; // in order to select the shape of the camera
setAttr -e -k 1 -cb 1 ($myCamera[0]+"."+"vrayCameraPhysicalISO");
Message 9 of 9
bmagner888
you can also batch the process by using an array and consoildate steps if you need to do this with more than one attribute.
string $obj = "someObjectName" //enter an object name or query from selection (`ls -sl`)
string $atts=["vrayCameraPhysicalISO", "someOtherAttr", "anotherAttr"] //etc.
//loop through list and apply all
for ($att in $atts){
    //only proceed if attribute actually exists on object (avoids errors)
    if (`attributeExists $att $obj`) { setAttr -e -k 1 -cb 1 ($obj+"."+$att); }
