Script needed for switching Anim Evaluation Mode to 'Parallel' and checking on GPU
bwhitmire01
bwhitmire01
  Hi! I'm an animator at a studio that is running into issues with their tools that is resetting the Evaluation mode every time they are used. Until the bug is addressed, it would be amazing if there was a script we could get that would turn on Parallel WITH GPU option checked on. Thanks so much for your time!
In a perfect world it would be this script (below) but would also include 'checking on the GPU function' as well!
import maya.cmds as cmds
cmds.evaluationManager(mode="parallel")
- Brian
Kahylan
Hi!
all you need to do is overwrite the gpuOverride variable using optionVar after the evaluation mode is changed.
cmds.optionVar(iv = ["gpuOverride",1])
I hope this helps!
bwhitmire01
Thank you so much! Looks like this is doing the trick @Kahylan! Much appreciated!!
