ya sure sorry it took so long, but i had to try and snip my code to something more manageable the first code is my UI code.
import maya.cmds as cmds
import pymel.core as pm
class UIMain():
def __init__(self, parent=None):
self.winName = 'PR_Animhub'
if pm.window(self.winName, exists=True):
pm.deleteUI(self.winName)
if pm.dockControl("animHubDock", label = "TIP_Animhub", exists = True) == True:
pm.deleteUI("animHubDock")
pm.window(self.winName, w=200,h=300,mnb=True,mxb=False,sizeable=True,resizeToFitChildren=True)
pm.showWindow(self.winName)
#blabla this middle part is not important .
#below is the unity path checkbox
#main Layout start
self.mainLay = pm.columnLayout(adjustableColumn=True)
#End layout start
self.endframe01 = pm.frameLayout(parent=self.mainLay,label='End',cll=1,cl=False,mh=5)
self.rowco25 = pm.rowColumnLayout(parent=self.endframe01,numberOfColumns=5,height = 100,columnAttach=[1,'left',5])
self.servChkbox = pm.checkBox(parent=self.rowco25,label = 'Server location', value = True )
self.serverPath = pm.textField(parent = self.rowco25,width = 240,text = 'R:/Prototype/characters')
pm.separator(parent=self.rowco25,width = 10,visible=False)
self.serverBrowse = pm.button(parent=self.rowco25, label = ". . .", command=pm.Callback(self.browseServFn))
pm.text(label=' Server Char folder')
#self.cleanupBtn = pm.button(parent = self.rowco25, label = 'AnimBake',command = pm.Callback(self.animBakeFn))
self.unityChkbox = pm.checkBox(parent=self.rowco25,height = 25,label = 'Unity Location', value = True)
self.unityPath = pm.textField(parent = self.rowco25,width = 240,text = 'D:/[Project]/Assets/ArtistFolder/LFS/Models/Characters')
self.unityBrowse = pm.button(parent=self.rowco25, height = 20,label = ". . .", command=pm.Callback(self.browseUnityFn))
pm.text(label=' Local Unity Char folder')
self.gmoviesChkbox = pm.checkBox(parent=self.rowco25,height = 25,label = 'GDrive Movies', value = True)
self.gmoviesPath = pm.textField(parent = self.rowco25,width = 240,text = 'D:/GoogleDrive/Character Anim Movies/Milestone 1')
self.gmoviesBrowse = pm.button(parent=self.rowco25, height = 20,label = ". . .", command=pm.Callback(self.browseUnityFn))
pm.text(label=' Gdrive Movies folder')
pm.button(parent=self.rowco25, label = "AnimBake", command=pm.Callback(self.animBakeFn))
#end layout end
def browseServFn(self, *args):
pathholder = pm.fileDialog2(caption = "Character Directory" , dialogStyle=2, fileMode = 2, okCaption = "Select")
pm.textField(self.serverPath,edit = True, text = str(pathholder[0]))
def browseUnityFn(self,*args):
pathholder = pm.fileDialog2(caption = "Unity Character Directory" , dialogStyle=2, fileMode = 2, okCaption = "Select")
pm.textField(self.unityPath,edit = True, text = str(pathholder[0]))
def animBakeFn(self, *args):
try:
reload(Redeye_FBXBaker)
except:
import Redeye_FBXBaker
x=UIMain()
and the next snip is my animation bake code. Basically It will bake the animation ready to use for Unity. The only issue is, I want my UI to pass a string to my "Redeye_FBXBaker" function. So we can copy the result of the playblasts / FBX files into multiple locations.
import maya.mel as mel
import random
import os
import sys
import subprocess
PLAYER = 'pl_'
MOB = 'mob_'
BOSS = 'bs_'
fbxFolder='FBX'
fbxExt='.fbx'
def listCtrls():
the usual list selection
if len(cmds.ls(selection=True)) == 0 :
cmds.confirmDialog(title='Selection Error',message='\n'+'You should select something',button = 'Ok',messageAlign='left',icon = 'warning')
if len(cmds.ls(selection=True)) > 1 :
cmds.confirmDialog(title='Selection Error',message='\n'+'You should select one thing',button = 'Ok',messageAlign='left',icon = 'warning')
elif len(cmds.ls(selection=True)) == 1:
return cmds.ls(selection=True)
def filenameManager():
eg for character file D:/[Project]/Unnamed/scenes/pl_dod/01_original/pl_dod01_original_flinch_02.ma
output
[0] filepath : D:/[Project]/Unnamed/scenes/pl_dod/01_original
[1] fbx export filename : pl_dod01_original@flinch
[2] file extension : ma
[3] iteration : 02
[4] characterName
[5] playblast local folder :
[6] characterFolder : pl_dod
[7] characterVersion : 01_original
filename=os.path.basename(pm.system.sceneName())
fileExt=os.path.splitext(pm.system.sceneName())[1]
fileloc=os.path.dirname(pm.system.sceneName())
characterFolder = fileloc.split("/")
print '#########################'
for char in characterFolder :
if "pl_" in char :
print "this character is PLAYER"
characterFolder = char
if "bs_" in char :
print "this character is BOSS"
if "mob_" in char :
print "this character is MOB"
print 'Character is : %s' % characterFolder
characterVersion = fileloc.split("/")[-1]
if "pl_" or "mob_" or "bs_" in characterVersion:
characterVersion = "01_original"
print 'Charcter Version : %s' % characterVersion
fileIteration = filename.split(fileExt)[0].split("_")[-1]
#knockout the iteration from filename.
filenameList = filename.split(fileExt)[0].split("_")
playblastName = '_'.join(filenameList)
del filenameList[-1]
filenameList[2] = filenameList[2]+'@'+filenameList[3]
ExportFilename='_'.join(filenameList)
#For playblast folder
characterName=filename.split(fileExt)[0].split("_")[0]+'_'+filename.split(fileExt)[0].split("_")[1]
#For playblast name
return fileloc, ExportFilename, fileExt, fileIteration, characterName, playblastName , characterFolder, characterVersion
def makeDir(path):
input a path to check if it exists, if not, it creates all the path
:return: path string
if not os.path.exists(path):
os.makedirs(path)
def exportFBX(file1):
try :
return pm.system.exportSelected(file1[0]+'/'+fbxFolder+"/"+file1[1]+fbxExt, force = 1)
except :
print "fbx folder doesn't exist"
makeDir(file1[0]+'/'+fbxFolder)
return pm.system.exportSelected(file1[0]+'/'+fbxFolder+"/"+file1[1]+fbxExt,force = 1)
def _getPlaybackTimeRange():
get playback time range
AnimSt=cmds.playbackOptions( animationStartTime=True,query=True )
AnimEnd= cmds.playbackOptions(animationEndTime=True,query=True )
return AnimSt, AnimEnd
def _cleanupNamespace():
find the reference, import it,
finds the prefix of the reference and cleans up the namespace
for item in listCtrls():
pre=str(listCtrls()[0])
prefix = pre.rsplit(":")[0]
print 'RIG is %s' % prefix
ref=cmds.referenceQuery( item, filename=True )
cmds.file(ref,importReference=True)
cmds.namespace(mv=(prefix,":"),force=True)
cmds.namespace(rm = prefix)
print "namespace deleted and cleaned up"
def bakeJntMesh():
#rest of bake fn
allObjects = cmds.ls(l=True)
jointsOnly=[]
meshy=[]
cmds.select(clear = True)
for obj in allObjects:
if cmds.nodeType(obj) == 'joint':
jointsOnly.append(obj)
cmds.setAttr((str(obj)+".segmentScaleCompensate"), 0)
#cmds.bakeSimulation(jointsOnly, t=(AnimSt,AnimEnd),at=["rx","ry","rz","tx","ty","tz","sx","sy","sz"])
cmds.bakeResults(jointsOnly,simulation=True, t=(_getPlaybackTimeRange()[0],_getPlaybackTimeRange()[1]),at=["rx","ry","rz","tx","ty","tz","sx","sy","sz"])
cmds.select(cmds.listRelatives(cmds.ls(type='mesh'),type='transform',p=True))
cmds.bakeResults(t=(_getPlaybackTimeRange()[0],_getPlaybackTimeRange()[1]),at=["visibility"])
#finish baking
#now search for correct items and add it to your selction.
#check for model_root
if cmds.objExists('model_root') == True :
cmds.select('model_root')
cmds.select(hi=True)
cmds.select('model_root',d=True)
cmds.select(jointsOnly,add=True)
#cmds.confirmDialog(title='Success',message='\n'+'Bake Successful! Yay!',button = 'Ok',messageAlign='left',icon = 'information')
else:
cmds.confirmDialog(title='Selection Error',message='\n'+'model_root / model_root_fix doesnt exists',button = 'Ok',messageAlign='left',icon = 'warning')
def selectMainRef():
cmds.select( clear=True )
correctNode=[]
allnurbs=cmds.listRelatives(cmds.ls(type='nurbsCurve'),p=True)
for nurb in allnurbs:
if str.lower(str(nurb.split(":")[-1])) == 'world_ctrl':
cmds.select(nurb)
correctNode=cmds.ls(selection=True)
return correctNode[0]
def muteWorld(world):
cmds.currentTime(1)
cmds.mute(str(world)+'.translateZ')
cmds.mute(str(world)+'.translateX')
cmds.mute(str(world)+'.translateY')
def createPlayblast(filename1):
#search for local movies folder
#moviesFolder=pm.workspace(query=True, active=True)+'/movies/'+filename1[6]+'/'+filename1[7]+'/'
print moviesFolder
panelnow=cmds.getPanel(wf=True)
cmds.modelEditor(panelnow, e=1, displayLights='flat')
thingstoHide = ['nurbsCurves', 'joints','motionTrails','locators','ikHandles']
# for loop to check through all 4 items on top.
for thing in thingstoHide:
kwargs = {'query': True, thing: True}
thingCheck = cmds.modelEditor(panelnow, **kwargs)
if thingCheck == True :
kwargs = {'edit': True, thing: False}
else :
print "%s is already hidden " % thing
return pm.playblast(format='qt',cc=True,filename=moviesFolder+filename1[5],fo=True,percent=100,compression='H.264',quality=100,width=960,height=540)
#except :
#cmds.confirmDialog(title='Error',message='\n'+'Playblast creation error+'\n, button = 'Ok',messageAlign='left',icon = 'information')
def mainBakefunction():
compile all scripts bake all meshes and joints of related reference.
clean up namespace
file2=filenameManager()
pbloc=createPlayblast(file2)
muteWorld(selectMainRef())
selectMainRef()
_cleanupNamespace()
bakeJntMesh()
fbxName = exportFBX(filenameManager())
#cmds.confirmDialog(title='Success',message='\n'+'FBX Export Successful! Yay!'+'\n'+fbxName+'\n'+'Playblast Successful'+'\n'+ pbloc , button = 'Ok',messageAlign='left',icon = 'information')
#tentatively integrated like crap here
cmds.file(newFile=True,force=True)
cmds.file(str(file2[0]+'/'+file2[5]+file2[2]), open=True)
return file2[6],file2[7]
def grabDataFromUI():
haven't figured out how to do this yet.
so... yeap. And if anyone has a good idea how to improve my script , your comments are appreciated.
