Running Unfold3D in standalone
rkovach
rkovach
I am trying to use Unfold3D in a maya.standalone session, however the command is trying to access the global progress bar and fails.
Since Unfold3D is a separate plugin, the "Unfold3D" is undocumented.
RuntimeError: progressBar -edit -beginProgress -isInterruptable true -status "Unfold3D" -maxValue 100 $gMainProgressBar;
Line 1.106: "$gMainProgressBar" is an undeclared variable.
progressBar -edit -status "Collecting data..." $gMainProgressBar;progressBar -edit -progress 1 $gMainProgressBar;
Line 1.65: "$gMainProgressBar" is an undeclared variable.
Line 1.113: "$gMainProgressBar" is an undeclared variable.
progressBar -edit -status "[1/4] Import Data" $gMainProgressBar;progressBar -edit -progress 1 $gMainProgressBar;
Line 1.64: "$gMainProgressBar" is an undeclared variable.
Line 1.112: "$gMainProgressBar" is an undeclared variable.
progressBar -query -isCancelled $gMainProgressBar;
Line 1.50: "$gMainProgressBar" is an undeclared variable.
Unfold3D command failed:
cheng_xi_li
Autodesk Support
Autodesk Support
Hi rkovach,
UI commands are not supported in Maya Batch(Standalone) mode. Here is the detail. You'll need to remove UI related commands.
Your,
Li
rkovach
Unfold3D is a 3rd party plugin licensed by Autodesk for inclusion in Maya. The plugin provides the "Unfold3D" command, but it is this command that is calling the UI. I cannot remove UI related commands, because they are built into the plugin itself.
In order to remove the UI calls, I would need access to the source code and re-compile it myself.
cheng_xi_li
Autodesk Support
Autodesk Support
Hi rkovach,
In that case, I am afraid it is impossible to run this command in batch mode. Sorry about that.
BTW, I talked with our engineers earlier today. It is possible to check whether Maya is running in batch mode with about -b command and you can create a dummy global proc for progressBar. It might work, but it could cause some issues with this hack.
Yours,
Li
