Retrieve text from a PySide QLineEdit
I am new to PySide and am experimenting with it in Autodesk Maya.
I have a text code from Chris Zurbrigg. I am getting a good handle of how to setup a UI, but I am running into one major problem.
How do I retrieve the text from a QLineEdit outside of the class?
Ex:
If the QLineEdit is for a username.
How do I retrieve the username text, in a function, outside of this UI?
Here is the code:----------------------------------------------------------------------------------
import traceback
from PySide import QtCore
from PySide import QtGui
from shiboken import wrapInstance
import maya
.cmds as cmds
import maya
.OpenMayaUI as omui
def maya_main_window
    Return the Maya main window widget as a Python object
    main_window_ptr = omui.MQtUtil.mainWindow()
    return wrapInstance(long(main_window_ptr), QtGui.QWidget)
class TestUi(QtGui.QDialog😞
    test_signal = QtCore.Signal()
    def __init__
(self, parent=maya_main_window()):
        super(TestUi, self).__init__(parent)
    def create
(self😞
        Create the UI
        self.setWindowTitle("TestUi")
        self.setWindowFlags(QtCore.Qt.Tool)
        self
.create_controls()
        self.create_layout()
        self.create_connections()
    def create_controls
(self😞
        Create the widgets for the dialog
        self.push_button = QtGui.QPushButton("QPushButton")
        self.check_box_01 = QtGui.QCheckBox("QCheckBox 01")
        self.check_box_02 = QtGui.QCheckBox("QCheckBox 02")
        txt
        self.line_edit = QtGui.QLineEdit()
        self.line_edit.setPlaceholderText('Enter Name')
        self.line_edit.setToolTip('Enter Your Name in the Text Field.')
        self.line_edit.setObjectName('testLineEdit')
        self
.close_btn = QtGui.QPushButton("Close")
        self.close_btn.clicked.connect(self.close)
    def create_layout
(self😞
        Create the layouts and add widgets
        check_box_layout = QtGui.QHBoxLayout()
        check_box_layout.setContentsMargins(2, 2, 2, 2)
        check_box_layout.addWidget(self.check_box_01)
        check_box_layout.addWidget(self.check_box_02)
        main_layout
= QtGui.QVBoxLayout()
        main_layout.setContentsMargins(6, 6, 6, 6)
        main_layout
.addWidget(self.line_edit)
        main_layout.addWidget(self.close_btn)
        main_layout.addStretch()
        self
.setLayout(main_layout)
    def create_connections
(self😞
        Create the signal/slot connections
        self.line_edit.editingFinished.connect(self.on_text_changed)
    # SLOTS
    def on_text_changed
(self😞
        print("Text changed")
        print self.line_edit.text()
if __name__
== "__main__":
# Development workaround for PySide winEvent error (Maya 2014)
    # Make sure the UI is deleted before recreating
    try:
        test_ui.deleteLater()
    except:
        pass
# Create minimal UI object
    test_ui = TestUi()
# Delete the UI if errors occur to avoid causing winEvent
    # and event errors (in Maya 2014)
    try:
        test_ui.create()
        test_ui.show()
    except:
        traceback.print_exc()
cheng_xi_li
Autodesk Support
Autodesk Support
Hi Nathan,
You can add a method in your TestUi class to expose the string like below:
    def getLineText(self):
        return self.line_edit.text()
If you want to find your window and get its text, you'll need to set an object name for your window.  You can add following code in the create function
        self.setObjectName('testWindow')
Then, you can use following code to find the window and get the text
        mayaMainWindow = maya_main_window()
        testWindow = mayaMainWindow.findChild(TestUi, "testWindow")
        print testWindow.getLineText()
Yours,
Li
Awesome!  Just what I was looking for.
Thank you!
