Requesting a tiny script : )
I was hoping someone would be able to write something up for me really quickly - I only ask because I know it won't be difficult for someone with mel or python knowledge
-for each object (skeletal joint) selected
-disable "Segment Scale Compensate" from the attribute editor
i currently have this, but its throwing array errors
string $sel[] = `ls -sl`;
int $i = 0;
int $size = size($sel);
for($i = 0; $i < $size; $i++)
setAttr ($sel[$i] + ".segmentScaleCompensate") 1;
You will earn 1 million virtual high fives and my love for eternity
Cory_XD
I think you just need to filter for joints in your first line:
string $sel[] = `ls -sl -type "joint"`;
I tried with a simple joint chain and some primitives parented in and had an error that pCone1 doesn't have segmentScaleCompensate so give this a shot.
Cory "Mr. Entertainment" Mogk
http://area.autodesk.com/blogs/cory
It's still saying that $sel is not an array (line 6)
I'm going to try restarting maya
yea.. I restarted maya and the original script works. yours does too!
Cory_XD
I wonder if you did something like:
string $sel;
and then:
string $sel[];
Maya doesn't llike you redelaring the type. Other than restarting you could make a new variable name.
