How to save an object's transforms relative to another object?
In mel, how would you save object x's transform data (translation and rotation) relative to another object y, and put this into a variable?
In maxscript, I could get this relationship by:
matrix = x.transform * inverse y.transform
Then:
z.transform = matrix * y.transform
Obj z would snap to the translation and rotation of x relative to y.
It is not clear how to do this in mel, using the xform, getAttr or setAttr commands. Does anybody know how?
Thanks!
First of all you need to make sure that node's type is 'transform'
if(`nodeType  $node` == "transform"){
  //grab matrix there
if node is not transform but shape you may try to find its transfomation node:
string $parents[] = `listRelatives -fullPath -parent $node`;
$transform = $parents[0];
and then grab the matrix from the attribute
float $m[] = `getAttr ($transform+".xformMatrix")`;
you can also grab this way inverseMatrix, worldInverseMatrix or parentInverseMatrix.
or you can use xfrom command
float $m[] = `xform -q -m $transform`;
however in both cases you get an array of 16 floats and you need to
convert it to MEL matrix to perform maxtrix*point multiplication
matrix $mt[4][4] = <<$m[0], $m[1], $m[2], $m[3];
$m[4], $m[5], $m[6], $m[7];
$m[8], $m[9], $m[10], $m[11];
$m[12], $m[13], $m[14], $m[15]>>;
Hope it helps. Not so handy as in MaxScript 😉
