replacing file node's image name attribute with a string
Hi, whenever I open a file, that was used by another user before, often the texture doesn't load. So I'm writing a script to source for the texture automatically. I know we should set project and all that but because of the structure of my project it is not possible.
So far, with some simple python i could find the material. And I have the path to where the correct texture location should be, but I don't know how to find the file node and how to replace the "image Name' path on my file node.
Can someone point me to the right direction? what command should i use to
1) find the file node
2) query this attribute and
3) how can i edit this attribute.
rajasekaransurjen
Try the "File Texture Manager" script....
/// Procedure Name :	FileTextureManager_2018
///	Version :	4.0.5
/// Updated :	Aug 1, 2017
/// Updated By :	 Parabhdeep Singh
/// Contact :	[email protected]
/// Author :	Crow Yeh (YE Feng)
/// History :
///		v4.0.5	Fixed problem of using it in Maya 2017.
///		v4.0.5	Support Maya version up to 2018.
///		v4.0.5	Now compatible with Maya 2017
/// Description :
///		File Texture Manager works on Windows/IRIX/Linux/MAC, manages file textures in a handy way.
///		FTM's basic functions:
///		1. Analyse scene file textures and give texture existence report.
///		2. Copy or move the original texture files to user defined path (customizable).
///		3. Update file textures' path info.
///		4. Handle path strings. eg. replace string, add prefix, append suffix...
///		FTM's extra fuctions:
///		1. Substitute file texture's path root string. eg. redirecting sourceiamges...
///		2. Memory efficiency setup for textures. (BOT for Maya and .map for mentalray.)
///		3. Filter type batch set.
///		4. Texture file format conversion.
/// How to use :
///		Put the script in your scripts folder then start Maya. Type
///		and execute	"FileTextureManager_2018" in command line or Script
///		Editor, an UI window will appear. Then follow the help in the UI
///		window to finish your job. Have fun!
/// Inputs :	None
/// Return :	None
/// All Rights Reserved .
// SCRIPT Starts //
// Procedure to check selection
proc int FTM_SelCheck(string $nodes[]){
int $sel = 0;
if (size($nodes))
	$sel = 1;
else
	confirmDialog -t "File Texture Manager" -m "At least one file texture node must be selected!" -b "OK";
return $sel;
// Procedure to remind user that job finished.
proc FTM_END(){
		confirmDialog -t "File Texture Manager" -m "Job finished.\nRefer to Script Editor for details." -ma center -b "OK";
// Procedure to give logs
proc FTM_Log (string $type, string $node, string $log) {
string $finLog;
if (size($node))
	$log = $node + "\n";
else
	$log = "\t" + $log + "\n";
switch ($type) {
	case "start":
		$finLog = "\n***************************************************************************************************************\n\
File Texture Manager Log starts...\n\
***************************************************************************************************************\n";
	break;
	case "end":
		$finLog = "***************************************************************************************************************\n\
File Texture Manager Log ends...\n\
	break;
	default:
		$finLog = $log;
	break;
print $finLog;
// Get the right format of path(folder) to match current OS.
proc string FTM_GetPath (string $FTM_FileOrPath, string $FTM_OldPath)
//$FTM_FileOrPath	Input type: file or path
//$FTM_OldPath		The input
	//Do not use 'fromNativePath' here
	//that only works on Windows!
	$FTM_OldPath = `substituteAll "\\\\" $FTM_OldPath "/"`;
	//Only want the path.
	if ($FTM_FileOrPath == "file")
		$FTM_OldPath = `dirname $FTM_OldPath`;
	//Get rid of the slash at the end.
	$FTM_OldPath = `substitute "/*$" $FTM_OldPath ""`;
	//Get the right path.
	string $FTM_RightPath;
	if (size($FTM_OldPath)) $FTM_RightPath = `toNativePath ($FTM_OldPath + "/")`;
	return $FTM_RightPath;
// Get the right format of input file's fullname (including path) to match current OS.
// Return a string array, the first element is the right format of the input file's
// fullname (including path), the second element is the shortname of input file (without path).
proc string[] FTM_GetFile (string $FTM_OldFullPath)
	string $FTM_RightPath[];
	string $FTM_PathElements[];
	int $FTM_PathElementsSize;
	// fullname
	$FTM_OldFullPath = `substituteAll "\\\\" $FTM_OldFullPath "/"`;
	$FTM_RightPath[0] = `toNativePath $FTM_OldFullPath`;
	$FTM_PathElementsSize = `tokenize $FTM_OldFullPath "/" $FTM_PathElements`;
	$FTM_RightPath[1] = $FTM_PathElements[$FTM_PathElementsSize - 1];
// Analyse all the file texture nodes in current scene.
proc string[] FTM_FileTextureAnalyst ()
// All the file texture nodes maybe point to texture files in different paths(folders).
// Here I use  "group" to indicate different paths , which means there are n "groups" of
// different paths if the file texture nodes point to files in n different paths.
// The trick is to have an string array $FTM_Groups[], within which every element has corresponding
// path and nodes pointing to that path are concatenated togather with a "*", which is not supposed to appear in path or name.
// Every element has a form style of "path*node1*node2*node3..."
// Leave $FTM_Groups[0] for empty path, which means node's texture file was not specified.
// Leave $FTM_Groups[1] for files without path, which means only texture file's short name was presented but path info was missing.
	// All the file texture nodes found in current scene.
	global string $lsCmd;
	string $FTM_Files[] = eval($lsCmd);
	// Different groups.
	string $FTM_Groups[];
	int $FTM_GroupsSize;
	if (size($FTM_Files)){
		$FTM_Groups[0] = "FTM_EmptySocket_FTM";
		$FTM_Groups[1] = "FTM_MissingPathSocket_FTM";
	// Figure out how many "groups" there are in current scene, and put each file texture node
	// into proper "group".
	for ($eachFile in $FTM_Files)
		$FTM_GroupsSize = size($FTM_Groups);
		// Get the path of current file texture node
		string $FTM_CurrentFullPath = substituteAll ("\\\\", `getAttr ($eachFile + ".fileTextureName")`, "/");
		string $FTM_CurrentPath = dirname ($FTM_CurrentFullPath);
		// File texutre was specified.
		if (size($FTM_CurrentPath))
			// Compare current path to all "groups" have been found. If matches then append current node
			// to current "group" and exist the compare loop immediately.
			// Remember that socket [0] is kept for nodes without texture file specified
			// Remember that socket [1] is kept for nodes with texture file specified but with the path info missing
			for ($j=2; $j<$FTM_GroupsSize; $j++)
				string $buffer[];
				tokenize $FTM_Groups[$j] "*" $buffer;
				// Get the path of current "group".
				string $FTM_OldPath =  $buffer[0];
				string $cmp1 = $FTM_CurrentPath;
				string $cmp2 = $FTM_OldPath;
				// Windows is not case sensitive to path
				if (`about -nt`) {
					$cmp1 = tolower($FTM_CurrentPath);
					$cmp2 = tolower($FTM_OldPath);
				if ($cmp1 == $cmp2)
					// Append current node to current group
					string $tmp = $FTM_Groups[$j];
					$tmp += "*" + $eachFile;
					$FTM_Groups[$j] = $tmp;
					break;
			// No "group" matches means new "group" was found.
			if ($j >= $FTM_GroupsSize)
				// Create a new "group" and append current file texure node.
				$FTM_Groups[$FTM_GroupsSize] = $FTM_CurrentPath + "*" + $eachFile;
				continue;
		// File texture was specified but the path info was missing
		else if (size($FTM_CurrentFullPath)){
			string $tmp = $FTM_Groups[1];
			$FTM_Groups[1] = $tmp;
		// File texture was not specified yet. Append current node to the first socket of groups
		else{
			string $tmp = $FTM_Groups[0];
			$FTM_Groups[0] = $tmp;
	select -cl;
	return $FTM_Groups;
// Edit the UI Controls after they've been built
proc FTM_EditUIControl (string $FTM_OptionColumn, string $FTM_HelpForm)
// Operation mode
	radioButtonGrp -e -on1 ("textFieldButtonGrp -e -en 0 -tx \"\" " + $FTM_OptionColumn + "|FTM_SourceDirectoryField")
			-on2 ("textFieldButtonGrp -e -en 1 -tx \"\" " + $FTM_OptionColumn + "|FTM_SourceDirectoryField")
			($FTM_OptionColumn + "|FTM_OperationMode");
// Set source directory
	textFieldButtonGrp -e -bc ("FTM_BrowseCmd \"file\" \"" + $FTM_OptionColumn + "|FTM_SourceDirectoryField\" \"Set_S.D.\" 0")
			($FTM_OptionColumn + "|FTM_SourceDirectoryField");
// Set target directory
	textFieldButtonGrp -e -bc ("FTM_BrowseCmd \"path\" \"" + $FTM_OptionColumn + "|FTM_TargetDirectoryField\" \"Set_T.D.\" 4")
			($FTM_OptionColumn + "|FTM_TargetDirectoryField");
// Make new folder
	checkBoxGrp -e -on1 ("textFieldGrp -e -en 1 -text \"\" " + $FTM_OptionColumn + "|FTM_NewFolderNameField")
			-of1 ("textFieldGrp -e -en 0 -text \"MyTextureFiles\" " + $FTM_OptionColumn + "|FTM_NewFolderNameField")
			($FTM_OptionColumn + "|FTM_MakeFolderChecker");
// Add prefix
	checkBox -e -onc ("textField -e -en 1 -text \"\" " + $FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_PrefixField")
			-ofc ("textField -e -en 0 -text \"prefix_\" " + $FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_PrefixField")
			($FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_AddPrefixChecker");
// Add suffix
	checkBox -e -onc ("textField -e -en 1 -text \"\" " + $FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_SuffixField")
			-ofc ("textField -e -en 0 -text \"_suffix\" " + $FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_SuffixField")
			($FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_AddSuffixChecker");
// Replace string
	checkBoxGrp -e -on1 ("textFieldGrp -e -en 1 -text \"\" " + $FTM_OptionColumn + "|FTM_OldStringField; textFieldGrp -e -en 1 -text \"\" " + $FTM_OptionColumn + "|FTM_NewStringField")
			-of1 ("textFieldGrp -e -en 0 -text \"OldString\" " + $FTM_OptionColumn + "|FTM_OldStringField; textFieldGrp -e -en 0 -text \"NewString\" " + $FTM_OptionColumn + "|FTM_NewStringField")
			($FTM_OptionColumn + "|FTM_ReplaceStringChecker");
// Help description field
	string $FTM_HelpDescription = "\n[Description]:\n";
		$FTM_HelpDescription += "  File Texture Manager works on Windows/IRIX/Linux/MAC, manages file textures in a very handy way.\n";
		$FTM_HelpDescription += "  FTM basic functions:\n";
		$FTM_HelpDescription += "  1. Analyse scene file textures.\n";
		$FTM_HelpDescription += "  2. Copy or move the original texture files to user defined path.\n";
		$FTM_HelpDescription += "  3. Update file textures' path.\n";
		$FTM_HelpDescription += "  4. Mentalray texture node is supported too.\n";
		$FTM_HelpDescription += "  FTM extra functions:\n";
		$FTM_HelpDescription += "  1. Substitute file texture path's root string. eg. redirecting sourceiamges...\n";
		$FTM_HelpDescription += "  2. Memory efficiency setup/unset for file textures according to their resolution. Textures larger than Threshold (in either x or y) will be set to use renderer prefered format (BOT for Maya and .map for mentalray) in setup mode. Corresponding memory-efficient file will be automatically generated if needed. When unset, all textures smaller than threshold in both x and y will be set to use normal textures, from which file the memory efficient texture was generated. BOT unset assume normal texture exist in the same directory. Mentalray .map unset will first check if the normal texture exist. If not, FTM will try to extract one from the .map file. Nodes pointing to sequences will be ignored.\n";
		$FTM_HelpDescription += "  3. Set filter type to specified type for selected file nodes.\n";
		$FTM_HelpDescription += "  4. Convert texture file format from \"From\" to \"To\" for selected file nodes. If \"From\" is not \"*\", only file nodes whose texture files format match \"From\" will be handled. For file nodes use image sequence as texture files, the range for conversion need to be specified, so only print out corresponding commands instead of really do the jobs. This function use Maya \"imgcvt\" and mentalray \"imf_copy\" ultility to do the conversion, so make sure them can be found in system executable path.\n\n";
		$FTM_HelpDescription += "[Work Flow]:\n";
		$FTM_HelpDescription += "  Step 1. Analyse scene file textures.(optional)\n";
		$FTM_HelpDescription += "  Step 2. Select scene file textures (nodes) you want to manage by checking on the related checkers in the UI. You can also do this by your own method, Eg. select them in Hypershade.\n";
		$FTM_HelpDescription += "  Step 3. Set options as needed.\n";
		$FTM_HelpDescription += "  Step 4. Do copy, move or set by pressing related button.\n\n";
		$FTM_HelpDescription += "[Tips]:\n";
		$FTM_HelpDescription += "  1. Always keep 2 different version for each texture file. Eg. \"abc_LowRes.tga\" is in low resolution while \"abc_HighRes.tga\" is in high resolution. Do your job using low-res textures to speed the interactant. Just remember to use FileTextureManager_2018 to reset each file texture to point to the related high-res texture before rendering. (Add prefix, add suffix or even replace string.)\n";
		$FTM_HelpDescription += "  2. The FileTextureManager_2018's UI does not update dynamically like what Attribute Editor does, so it is better to re-analyse scene file textures each time you finish an FTM job. This is not necessary if you do not use the Analyse function at all.\n\n";
		$FTM_HelpDescription += "[Notes]:\n";
		$FTM_HelpDescription += "  1. Final target directory will be equal to target directory plus new folder, if user decide to make a new folder.\n";
		$FTM_HelpDescription += "  2. Add suffix function has limitation on the texture file name. To be sure it work as desired, the file name must be in a regular format, Eg. \"filename.ext\", \"filename.[#...#].ext\", \"filename.ext.[#...#]\", etc.\n";
		$FTM_HelpDescription += "  3. Add prfix, add suffix and replace string can be executed at the same time to each file texture. Replace string is caculated first, then add suffix, and add prefix last.\n";
		$FTM_HelpDescription += "  4. It is highly recommended not to contain \".\" in prefix, suffix, old string and new string.\n";
		$FTM_HelpDescription += "  5. Sometimes process fails. The reason may be various. The most possible reason could be one of or both the following two: a. Texture file is not found in the source directory; b. Permission denied on reading or writing or deleting.\n\n";
		$FTM_HelpDescription += "[Details]:\n";
		$FTM_HelpDescription += "  1. Analysing scene file textures let you know how many file textures there are in the scene, where there are, whether they exist or not, etc. It also allows user select all the texture files point to same path by only one simple click.\n";
		$FTM_HelpDescription += "  2. How to choose operation mode depends on different source directory status. If file is there where it point to, use Automatic mode, otherwise use Manual mode.\n";
		$FTM_HelpDescription += "  3. Other functions are pretty definite as marked in the UI.\n";
	scrollField -e -text $FTM_HelpDescription ($FTM_HelpForm + "|FTM_HelpField");
// judge if the input string is format extension, sequence or just part of file basename
proc int FTM_FCWhatIs(string $string)
int $isWhat;
// 0 - format extension
// 1 - sequence number
// 2 - nothing, is just file basename
// 3 - bot
global string $FTM_FCAllFormats[];
$string = tolower($string);
if (stringArrayCount($string,$FTM_FCAllFormats))
	$isWhat = 0;
else if (size(match("[0-9]*",$string)) == size($string))
	$isWhat = 1;
else if ($string == "bot")
	$isWhat = 3;
else
	$isWhat = 2;
return $isWhat;
// judge texture file format, only according to the possible extension name
proc string[] FTM_FCFileRegularName(string $file)
$file = substituteAll ("\\\\", $file, "/");
string $fileRegularName[] = stringToStringArray(basename($file,""),".");
// try to make it like below
// [0] - file name
// [1] - the sequency number if presented, or ""
// [2] - the extension if presented, or ""
string $fileName;
string $seqNum;
string $fileFormat;
switch (size($fileRegularName))
	case 0: // sick!!!
	break;
	case 1:// only file name presented
		$fileName = $fileRegularName[0];
	break;
	case 2:// the second/last element could be sequence number, format extension or nothing;
		if (FTM_FCWhatIs($fileRegularName[1]) == 0)
			$fileFormat = $fileRegularName[1];
		else if (FTM_FCWhatIs($fileRegularName[1]) == 1)
			$seqNum = $fileRegularName[1];
		else // FTM_FCWhatIs($fileRegularName[1]) = 2, which means the second/last element is just part of file basename, sick!!!
			$fileName = basename($file,"");
	break;
	default: // there are 3 or more pieces. consider the last 2 only.
		string $lastPiece = $fileRegularName[size($fileRegularName)-1];
		if (FTM_FCWhatIs($lastPiece) == 0)
			$fileFormat = $lastPiece;
			$fileName = basenameEx($file);
			// strip the last piece to judge again
			$lastPiece = $fileRegularName[size($fileRegularName)-2];
			if (FTM_FCWhatIs($lastPiece) == 1)
				$seqNum = $lastPiece;
				$fileName = basenameEx($fileName);
		else if (FTM_FCWhatIs($lastPiece) == 1)
		else if (FTM_FCWhatIs($lastPiece) == 3) //bot
			$fileFormat = $fileRegularName[size($fileRegularName)-2] + ".bot";
			if (size($fileRegularName) == 3)
			else
				$lastPiece = $fileRegularName[size($fileRegularName)-3];
					$fileName = basenameEx(basenameEx(basenameEx($file)));
				else
					$fileName = basenameEx(basenameEx($file));
		else // really sick!!!
	break;
$fileRegularName[0] = $fileName;
$fileRegularName[1] = $seqNum;
$fileRegularName[2] = $fileFormat;
return $fileRegularName;
// check string $inputString,replace the first (count backwards) matching string $targetPattern with string $newPattern
proc string FTM_FCSubstituteLastPattern(string $inputString, string $targetPattern, string $newPattern)
$inputString = substituteAll("\\\\", $inputString, "/");// avoid to handle "\" in the path
//strip everything behind the last string $targetPattern's existence
string $exp1 = "^.*" + $targetPattern + "+";
string $noTail = match($exp1,$inputString);
//replace the last $targetPattern in $noTail with $newPattern
string $exp2 = $targetPattern + "+$";
string $newNoEnd = substitute($exp2,$noTail,$newPattern);
//replace $noTail part in $inputString with $newNoEnd
// substitute all special characters
string $badChar[] = {"+",".","^","$","[","]","(",")"};
for ($char in $badChar)
	$noTail = `substituteAllString $noTail $char ("\\"+$char)`;
string $exp3 = "^" + $noTail + "+";//take care of "\", so encode string.
string $outputString = substitute($exp3,$inputString,$newNoEnd);
$outputString = toNativePath($outputString);
return $outputString;
// to analyse the number of digits for input filename
proc int FTM_FCDigitsNumber(string $fileName)
string $fileRegularName[] = FTM_FCFileRegularName($fileName);
$fileName = FTM_FCSubstituteLastPattern($fileName,$fileRegularName[1],"*");
string $filesInSeq[] = `getFileList -fs $fileName`;
int $digiNum = 0;
for ($i=0;$i<size($filesInSeq);$i++)
	string $tmp[] = FTM_FCFileRegularName($filesInSeq[$i]);
	if ($digiNum <= size($tmp[1]))
		$digiNum = size($tmp[1]);
return $digiNum;
// the file format converter
proc FTM_FCGo(int $progressUI, string $sourceFormatUI, string $targetFormat, int $handleSeq, int $updatePath, int $removeOrig)
//int $progressUI			- need progress UI; 0 - No UI for progress, which is designed for command line uses.
//string $sourceFormatUI	- format convert from
//string $targetFormat		- format convert to
//int $handleSeq			- handle sequence textures; 0 - do not handle sequence textures.
//int $updatePath			- update path info; 0 - do not update path info.
//int $removeOrig			- remove original textures; 0 - do not remove original textures.
if (FTM_SelCheck(`ls -sl -typ file -typ file`)) {// if (0)
	waitCursor -state on;
	FTM_Log "start" "" "";
	// list for file nodes to be handled
	string $fileNodesList[] = FTM_FCGetMatches($sourceFormatUI);
	int $isSeq[];// if it is using an image sequence as texture
	int $isOneOfSeq[];// if it is using only one image of a whole sequence as texture.
	string $file;// current file to be converted
	string $fileFC;// current file in suitable naming for FC use
	string $fileUpdatePath;// current file in suitable naming for updatePath use
	string $fileRemove;// current file in proper naming for removing
	// build progress feedback only in UI mode
	if ($progressUI) {
		// base of progress feedback setup
		int $progress = 0;
		int $percentage = 0;
		progressWindow -t "FTM Working..." -pr $progress -ii 1 -min 0 -max `size($fileNodesList)`;
	// executes cooresponding commands for each file node specified.
	// the core process.
	for ($i=0;$i<size($fileNodesList);$i++){ //for loop (1)
		FTM_Log "" ($fileNodesList[$i]+":") "";
		if ($progressUI){
			// Check if the dialog has been cancelled
			if ( `progressWindow -q -ic` ){
				FTM_Log "" "User cancelled." "";
				break;
			$progress = $i+1;
			$percentage = $progress * (100/size($fileNodesList));
			progressWindow -e -pr $progress -st ("Handling " + $fileNodesList[$i] + "     ......  " + $percentage + "%");
		$file = toNativePath(substituteAll("\\\\",`getAttr ($fileNodesList[$i] + ".fileTextureName")`,"/"));
		$fileFC = $file;
		$fileRemove = $file;
		string $fileRegularName[] = FTM_FCFileRegularName($file);
		string $isBOT = `match "bot" $fileRegularName[2]`;
		if (size($isBOT)) {
			FTM_Log "" "Texture file is a BOT file. Skipped!" "";
			continue;
		string $targetFile = FTM_FCSubstituteLastPattern($file,$fileRegularName[2],$targetFormat);
		// it is bad that a file has no extension to indicate its format, so add one if needed.
		if (!size($fileRegularName[2]))
			$targetFile += "." + $targetFormat;
		$fileUpdatePath = $targetFile;
		string $cmp1,$cmp2;
		$cmp1 = $fileUpdatePath;
		$cmp2 = $fileRemove;
		if (`about -nt`) {
			$cmp1 = toNativePath(tolower($cmp1));
			$cmp2 = toNativePath(tolower($cmp2));
		// skip all process if the file node was already handled before.
		if($cmp1 == $cmp2)
			FTM_Log "" "" "This file node was already handled before. Process skipped.";
		else{ //else (1)
			$isSeq[$i] = 0;
			$isOneOfSeq[$i] = 0;
			if (`nodeType $fileNodesList[$i]` == "file" && size($fileRegularName[1])) {
				if (`getAttr ($fileNodesList[$i] + ".useFrameExtension")`)
					$isSeq[$i] = 1;
				else
					$isOneOfSeq[$i] = 1;
			//commands to execute
			int $isMR_c = 0; //create .map file
			int $isMR_x = 0; //extract .map file
			if ($fileRegularName[2] == "map" && $targetFormat != "map")
				$isMR_x = 1;
			else if ($fileRegularName[2] != "map" && $targetFormat == "map")
				$isMR_c = 1;
			string $cmdFC = "system(\"";
			if ($isMR_c)
				$cmdFC += "imf_copy -p -r";
			else if ($isMR_x)
				$cmdFC += "imf_copy";
			else
				$cmdFC += "imgcvt -t " + $targetFormat;
			string $cmdUpdatePath = "setAttr -typ \"string\" " + $fileNodesList[$i] + ".fileTextureName ";
			string $cmdRemoveOrig = "sysFile -del \"";
			if (!$handleSeq && $isSeq[$i])
				FTM_Log "" "" "Sequence was not selected to be handled. Skipped.";
			else { //else (2)
				// need to handle sequence textures
				if ($handleSeq && $isSeq[$i]){
					string $padding = "";
					for ($j=0;$j<FTM_FCDigitsNumber($file);$j++)
						$padding += "@";
					$targetFile = FTM_FCSubstituteLastPattern($targetFile,$fileRegularName[1],$padding);
					$fileFC = FTM_FCSubstituteLastPattern($file,$fileRegularName[1],$padding);
					$fileRemove = FTM_FCSubstituteLastPattern($file,$fileRegularName[1],"*");
					//command for sequence
					if (!$isMR_c && !$isMR_x)
						$cmdFC += " -n startIn endIn stepIn -N startOut endOut stepOut";
				$cmdFC += " \\\"" + encodeString($fileFC) + "\\\" \\\"" + encodeString($targetFile) + "\\\"";
				if ($isMR_c || $isMR_x)
					$cmdFC += " " + $targetFormat + "\")";
				else
					$cmdFC += "\")";
				// only do the convertion when target file doesn't exist,
				// or convertion has been done before for other file node that shares the same texture.
				if (`file -q -ex $fileUpdatePath`)
					FTM_Log "" "" "Convertion skipped. New format texture exists, maybe convertion has been done before.";
				else{ //else (3)
					if (!$isSeq[$i]){
						// system feedback
						string $cmdFCFeedback = eval($cmdFC);
						if (size($cmdFCFeedback))
							FTM_Log "" "" $cmdFCFeedback;
							FTM_Log "" "" ("Convertion succeeded. Converted from \"" + $fileFC + "\" to \"" + $targetFile + "\".");
						else
							FTM_Log "" "" "Convertion failed. Could be file permission problem, disk capacity problem or source texture is of unknown/unsupported format.";
					else { // for sequence, only print out command to execute.
							FTM_Log "" "" ("Sequence specified. Command to execute (format conversion):" + $cmdFC);
						else
							FTM_Log "" "" "Sequence specified. Use \"imf_copy\" to convert your tetures. A simple loop might be needed.";
				}// else (3)
				// need to update path info
				if ($updatePath) {// if (1)
					$cmdUpdatePath += "\"" + encodeString(toNativePath($fileUpdatePath)) + "\";";
					$cmdRemoveOrig += encodeString($fileRemove) + "\";";
					if (!$isSeq[$i]){// if (2)
						if (`file -q -ex $fileUpdatePath`){ // if (3)
							if(catchQuiet(eval($cmdUpdatePath))) {
								FTM_Log "" "" "WARNING: Attribute \"fileTextureName\" is locked/connected and can NOT be modified!";
								FTM_Log "" "" "WARNING: Path updating failed. So Original Texture Removing will not be done even if it was selected to.";
							else {// else (3)
								FTM_Log "" "" ("Path updating succeeded. Set to \"" + (toNativePath($fileUpdatePath)) + "\".");
								// need to remove old textures
								// only remove old textures when updatePath is selected and updating succeeds
								if ($removeOrig){ //if (4)
									if ($isOneOfSeq[$i])
										FTM_Log "" "" "Only one file of a whole sequence is used as texture, no file in the sequence is supposed to be removed.";
									else if (!$isSeq[$i]){ // else if (1)
										if (!eval($cmdRemoveOrig))
											FTM_Log "" "" "Original texture removing failed, could be file permission problem.";
										else
											FTM_Log "" "" ("Original texture removing succeeded. Removed \"" + $fileRemove + "\".");
									} // else if (1)
								} // if (4)
							}// else (3)
						} // if (3)
						else
							FTM_Log "" "" "Convertion failed, Path Updating and Original Texture Removing will not be done even if they were selected to.";
					} // if (2)
					else { //else (4)
						FTM_Log "" "" ("Sequence specified. Command to execute (update path info):" + $cmdUpdatePath);
						if ($removeOrig)
							FTM_Log "" "" ("Sequence specified. Command to execute (remove original textures):" + $cmdRemoveOrig);
					}// else (4)
				} // if (1)
			} //else (2)
		} // else(1)
	} // for loop (1)
	// feedback ends
	if (!size($fileNodesList))
		FTM_Log "" "No texture is of specified format." "";
	if ($progressUI){
		// finish progress feed back
		progressWindow -ep;
		FTM_Log "end" "" "";
		// job done
		FTM_END;
	waitCursor -state off;
} // if (0)
// analyse all possible file nodes to find out those match user's specification
global proc string[] FTM_FCGetMatches (string $formatUI)
string $fileNodesList[]; // list for file nodes to be handled
string $tmpNodesList[] = `ls -sl -typ file -typ file`; // list for all (selected) file nodes, which need to be analyse.
if (`FTM_SelCheck $tmpNodesList`) {
	string $tmpNode; // each single file node in the list
	string $tmpFile; // file that $tmpNode point to.
	string $format = `optionMenu -q -v $formatUI`;
	if ($format!="*") {// format from specified, so only handle files with that format
		for ($tmpNode in $tmpNodesList)	{
			$tmpFile = `getAttr ($tmpNode + ".fileTextureName")`;
			string $tmpFileRegularName[] = FTM_FCFileRegularName($tmpFile);
			if (tolower($tmpFileRegularName[2]) == tolower($format))// extension matches, this file node need to be handled
				$fileNodesList[size($fileNodesList)] = $tmpNode;
	else // "*" was selected as format from, which means to handle all (selected) file nodes
		$fileNodesList = $tmpNodesList;
return $fileNodesList;
// info transfer, just to make sure FTM_FCGo can be run in command line.
global proc FTM_FCGatherInfo(string $FTM_ExtraFunctionColumn)
string $sourceFormatUI = $FTM_ExtraFunctionColumn + "|FTM_FCRow|FTM_FCSourceMenu";
string $targetFormat = `optionMenu -q -v ($FTM_ExtraFunctionColumn + "|FTM_FCRow|FTM_FCTargetMenu")`;
int $handleSeq = `checkBox -q -v ($FTM_ExtraFunctionColumn + "|FTM_SeqCheck")`;
int $updatePath = `checkBox -q -v ($FTM_ExtraFunctionColumn + "|FTM_UpdateCheck")`;
int $removeOrig = `checkBox -q -v ($FTM_ExtraFunctionColumn + "|FTM_RemoveCheck")`;
FTM_FCGo 	1
		$sourceFormatUI
		$targetFormat
		$handleSeq
		$updatePath
		$removeOrig;
// Command for Filter Setup
global proc FTM_FilterSetup(string $FTM_ExtraFunctionColumn)
string $Nodes[] = `ls -sl -typ file`;
if (`FTM_SelCheck $Nodes`) {
	int $filterType = `optionMenu -q -sl ($FTM_ExtraFunctionColumn+"|FTM_FilterTypeRow|FTM_FilterTypeMenu")` -1;
	string $filter = `optionMenu -q -v ($FTM_ExtraFunctionColumn+"|FTM_FilterTypeRow|FTM_FilterTypeMenu")`;
	int $progress = 0;
	progressWindow -t "FTM Working..." -pr $progress -ii 1 -min 0 -max `size $Nodes`;
	for ($i=0;$i<size($Nodes);$i++) {
		FTM_Log "" ($Nodes[$i]+":") "";
			break;
		$progress = $i;
		$percentage = $progress * 100 / size($Nodes);
		progressWindow -e -pr $progress -st ("Setting filter type, please wait......      " + $percentage + "%");
		string $cmd = "setAttr " + $Nodes[$i] + ".filterType " + $filterType;
		if (catchQuiet(eval($cmd)))
			FTM_Log "" "" "Attribute \"filterType\" is locked/connected and can NOT be modified!";
		else
			FTM_Log "" "" ("Set filter type to \"" + $filter + "\"");
	progressWindow -ep;
	FTM_END;
// Command for BOT setup
global proc FTM_BOTSetup(int $FTM_BOTMode, string $FTM_ExtraFunctionColumn)
//$FTM_BOTMode		-	1 Setup
//					-	0 Unset
string $FTM_FileNodes[]=`ls -sl -typ file`;
if (`FTM_SelCheck $FTM_FileNodes`) {
	int $progress = 0;
	progressWindow -t "FTM Working..." -pr $progress -ii 1 -min 0 -max `size $FTM_FileNodes`;
	for ($i=0; $i<size($FTM_FileNodes); $i++){
		FTM_Log "" ($FTM_FileNodes[$i]+":") "";
			break;
		$progress = $i;
		$percentage = $progress * 100 / size($FTM_FileNodes);
		progressWindow -e -pr $progress -st ("Setting BOT options, please wait......      " + $percentage + "%");
		// Do not handle sequence textures
		if (`getAttr ($FTM_FileNodes[$i] + ".useFrameExtension")`) {
			FTM_Log "" "" "Sequence specified, Skipped!";
			continue;
		int $resolution = `intFieldGrp -q -v1 ($FTM_ExtraFunctionColumn + "|FTM_BOTRow|FTM_BOTResFieldGrp")`;
		float $xRes = `getAttr ($FTM_FileNodes[$i] + ".outSizeX")`;
		float $yRes = `getAttr ($FTM_FileNodes[$i] + ".outSizeY")`;
		if ($FTM_BOTMode) {// Setup
			if ($xRes >= $resolution || $yRes >= $resolution) {
				string $FTM_File = `getAttr ($FTM_FileNodes[$i] + ".fileTextureName")`;
				$FTM_File = `substituteAll "\\\\" $FTM_File "/"`;
				string $FTM_TheBOT = `substitute "(\\.bot)*$" $FTM_File ""` + ".bot";
				string $BOTCmd = "makebot -c  -r " + $resolution + " -i \"" + $FTM_File + "\" -o \"" + $FTM_TheBOT + "\"";
				if (catchQuiet(eval($BOTCmd)))
					FTM_Log "" "" "BOT file generation failed. Could be permission issue or the BOT file already exists.";
				string $cacheCmd = "setAttr " + $FTM_FileNodes[$i] + ".useCache 1";
				string $pathCmd = "setAttr -typ \"string\" " + $FTM_FileNodes[$i] + ".fileTextureName \"" + $FTM_TheBOT + "\"";
				if (catchQuiet(eval($cacheCmd)))
					FTM_Log "" "" "WARNING: Attribute \"useCache\" is locked/connected and can NOT be modified!";
				else if (catchQuiet(eval($pathCmd)))
				else
					FTM_Log "" "" "BOT setup OK.";
			else
				FTM_Log "" "" ("Resolution \"" + $xRes + "x" + $yRes + "\" is LOWER than specified threshold, skipped!");
		else {// Cancel
			if ($xRes <= $resolution && $yRes <= $resolution) {
				string $cacheCmd = "setAttr " + $FTM_FileNodes[$i] + ".useCache 0";
				$FTM_File = `substitute "(\\.bot)*$" $FTM_File ""`;
				string $pathCmd = "setAttr -typ \"string\" " + $FTM_FileNodes[$i] + ".fileTextureName \"" + $FTM_File + "\"";
					FTM_Log "" "" "WARNING: Attribute \"fileTexturename\" is locked/connected and can NOT be modified!";
				else
					FTM_Log "" "" "BOT cancelled successfully.";
			else
				FTM_Log "" "" ("Resolution \"" + $xRes + "x" + $yRes + "\" is HIGHER than specified threshold, skipped!");
	progressWindow -ep;
	FTM_END;
// Command for mentalray memory-mapped texture (.map) setup
global proc FTM_MAPSetup(int $FTM_MAPMode, string $FTM_ExtraFunctionColumn)
//$FTM_MAPMode		-	1 Setup
//					-	0 Unset
	int $progress = 0;
			break;
		$progress = $i;
		progressWindow -e -pr $progress -st ("Setting up mentalray memory-mapped textures, please wait......      " + $percentage + "%");
			continue;
		int $resolution = `intFieldGrp -q -v1 ($FTM_ExtraFunctionColumn + "|FTM_MAPRow|FTM_MAPResFieldGrp")`;
		if ($FTM_MAPMode) {// Setup
				string $FTM_TheMAP = `substitute "(\\.map)*$" $FTM_File ""` + ".map";
				string $MAPCmd = "system(\"imf_copy -p -r \\\"" + (encodeString(`toNativePath $FTM_File`)) + "\\\" \\\"" + (encodeString(`toNativePath $FTM_TheMAP`)) + "\\\" map\")";
				if (`file -q -ex $FTM_TheMAP`){ // .map is already there.
					FTM_Log "" "" ("Mentalray memory-mapped texture file \"" + `toNativePath $FTM_TheMAP` + "\" already exists. FTM will directly use it.");
				} else {
					if (catchQuiet(eval($MAPCmd)))
						FTM_Log "" "" "Mentalray memory-mapped texture file generation failed. Could be permission issue or 'imf_copy' can not be found in system executable path.";
				string $pathCmd = "setAttr -typ \"string\" " + $FTM_FileNodes[$i] + ".fileTextureName \"" + $FTM_TheMAP + "\"";
				else
					FTM_Log "" "" "Mentalray memory-mapped texture setup accomplished.";
			else
		else {// Unset
				string $FTM_TheMAP = $FTM_File;
				$FTM_File = `substitute "(\\.map)*$" $FTM_File ""`;
				int $wrong = 0;
				if (!`file -q -ex $FTM_File`){
					FTM_Log "" "" ("Normal texture file \"" + `toNativePath $FTM_File` + "\" doesn't exist.");
					FTM_Log "" "" ("FTM is trying to extract one (in Maya iff format) from \"" + `toNativePath $FTM_TheMAP` + "\"");
					string $UnMAPCmd = "system(\"imf_copy \\\"" + (encodeString(`toNativePath $FTM_TheMAP`)) + "\\\" \\\"" + (encodeString(`toNativePath $FTM_File`)) + "\\\" iff\")";
					if (catchQuiet(eval($UnMAPCmd))) {
						$wrong = 1;
						FTM_Log "" "" ("WARNING: Extracting normal texture file from \"" + `toNativePath $FTM_TheMAP` + "\" failed.");
						FTM_Log "" "" "         Could be permission issue, or 'imf_copy' can not be found in system executable path, or original .map file is not a mentalray memory-mapped texture file.";
					} else
						FTM_Log "" "" ("Extraction succeed. => \"" + `toNativePath $FTM_File` + "\"");
				if (!$wrong) {
					else
						FTM_Log "" "" "Mentalray memory-mapped texture file unset accomplished.";
			else
	progressWindow -ep;
	FTM_END;
// Command to substitute path root
global proc FTM_Substitute(string $oldRootField, string $newRootField)
string $oldRoot = `textFieldButtonGrp -q -text $oldRootField`;
$oldRoot = substituteAll("\\\\",$oldRoot,"/");
string $newRoot = `textFieldButtonGrp -q -text $newRootField`;
$newRoot = substituteAll("\\\\",$newRoot,"/");
if (size($oldRoot)==0 || size($newRoot)==0)
	confirmDialog -t "File Texture Manager" -m "Both the Old Root filed and the New Root field must be filled!" -b "OK";
else {
	string $fileNodes[] = `ls -sl -typ file -typ file -typ psdFileTex`;
	if (`FTM_SelCheck $fileNodes`){
		waitCursor -state 1;
			$oldRoot = `substituteAllString $oldRoot $char ("\\"+$char)`;
		string $node;
		int $progress = 0;
		progressWindow -t "FTM Working..." -pr $progress -ii 1 -min 0 -max `size $fileNodes`;
		for ($i=0;$i<size($fileNodes);$i++) {
			FTM_Log "" ($fileNodes[$i]+":") "";
				break;
			$progress = $i;
			$percentage = $progress * 100 / size($fileNodes);
			progressWindow -e -pr $progress -st ("Redirecting, please wait......      " + $percentage + "%");
			string $old = `getAttr ($fileNodes[$i]+".fileTextureName")`;
			$old = `substituteAll "\\\\" $old "/"`;
			string $new = `substitute $oldRoot $old $newRoot`;
			string $cmd = "setAttr -typ \"string\" " + $fileNodes[$i] + ".fileTextureName \"" + $new + "\"";
			else
				FTM_Log "" "" ("Set to \"" + (toNativePath($new)) + "\"");
			if (!`file -q -ex $new`)
				FTM_Log "" "" ("WARNING: \"" + (toNativePath($new)) + "\" doesn't exist!");
		progressWindow -ep;
		FTM_END;
		waitCursor -state 0;
// Command executed when "Analyse Scene File Textures" button pressed.
global proc FTM_AnalyseFileTextures (string $FTM_ParentUI)
	string $FTM_Groups[] = `FTM_FileTextureAnalyst`;
	// Make sure the corresponding UI uniqe.
	if (`columnLayout -q -ex ($FTM_ParentUI + "|FTM_AnalysisCheckerColumn")`)
		deleteUI ($FTM_ParentUI + "|FTM_AnalysisCheckerColumn");
	if (size($FTM_Groups) == 0)
		text -e -l "No file textures found!" ($FTM_ParentUI + "|FTM_EmptyAnalysisText");
	else
		text -e -l "Analysis:" ($FTM_ParentUI + "|FTM_EmptyAnalysisText");
		setParent $FTM_ParentUI;
		columnLayout FTM_AnalysisCheckerColumn;
		int $FTM_Groups_Size = size($FTM_Groups);
		if ($FTM_Groups[0] == "FTM_EmptySocket_FTM")
			$FTM_Groups_Size -= 1;
		if ($FTM_Groups[1] == "FTM_MissingPathSocket_FTM")
		string $FTM_TotalResults = "Total " + size(eval($lsCmd)) + " file textures point to " + $FTM_Groups_Size + " (different) path(s) : ";
		text -l $FTM_TotalResults;
		text -l "" -h 10;
		// Analyse each file in each "group".
		for ($FTM_Group in $FTM_Groups)
			string $buffer[];
			tokenize $FTM_Group "*" $buffer;
			int $FTM_FilesStoredSize = size ($buffer)-1;
			string $FTM_CurrentPath = $buffer[0];
			string $FTM_FileTexturesAnalysis;
			// File texture not specified yet. In other words, empty file texture nodes.
			if ($FTM_CurrentPath=="FTM_EmptySocket_FTM" && $FTM_FilesStoredSize>0)
				$FTM_FileTexturesAnalysis = $FTM_FilesStoredSize + " texture(s) NOT specified. So they are NOT exist(s).";
			// File texture specified, but no path information.
			else if ($FTM_CurrentPath=="FTM_MissingPathSocket_FTM" && $FTM_FilesStoredSize>0)
				$FTM_FileTexturesAnalysis = $FTM_FilesStoredSize + " texture(s) have no path information. So they are NOT exist(s).";
			// Normal status.
			else
				if ($FTM_FilesStoredSize>0){
					// Correct the path format for current OS.
					$FTM_CurrentPath = `FTM_GetPath "path" $FTM_CurrentPath`;
					$FTM_FileTexturesAnalysis = $FTM_FilesStoredSize + " texture(s) point to \"" + (toNativePath($FTM_CurrentPath)) + "\"";
			// Queue the names of the files stored in current "group" for later quick selecting.
			string $FTM_CurrentFile[];
			string $FTM_CurrentFiles = "";
			// Strings used to hold files exist or notExist.
			string $FTM_Exist[] = {};
			int $FTM_ExistSize = 0;
			string $FTM_NotExist[] = {};
			int $FTM_NotExistSize = 0;
			for ($i=1; $i<size($buffer); $i++)
				// Store the names of files in current "group".
				$FTM_CurrentFile[$i] = $buffer[$i];
				$FTM_CurrentFiles = $FTM_CurrentFiles + $FTM_CurrentFile[$i] + " ";
				// Check if the file exsist or not, then asign the name to responding variable.
				string $FTM_CurrentFilePath = `getAttr ($FTM_CurrentFile[$i] + ".fileTextureName")`;
				if ( `file -q -ex $FTM_CurrentFilePath`)
					$FTM_Exist[$FTM_ExistSize] = $FTM_CurrentFile[$i];
					$FTM_ExistSize = $FTM_ExistSize + 1;
				else
					$FTM_NotExist[$FTM_NotExistSize] = $FTM_CurrentFile[$i];
					$FTM_NotExistSize = $FTM_NotExistSize + 1;
			if (size($FTM_FileTexturesAnalysis)) {
					string $FTM_MainChecker = `checkBox -l $FTM_FileTexturesAnalysis -al left`;
					FTM_Log "" "" $FTM_FileTexturesAnalysis;
				// Only build responding sub-checker for the files have path information.
				string $FTM_ExistSubChecker;
				string $FTM_NotExistSubChecker;
				if ($FTM_CurrentPath!="FTM_EmptySocket_FTM"  && $FTM_CurrentPath!="FTM_MissingPathSocket_FTM")
					columnLayout -adj 1 -cat left 30;
						// A list of exist files, which is used for selection.
						string $FTM_ExistFiles = "";
						for ($i=0; $i<$FTM_ExistSize; $i++)
							$FTM_ExistFiles = $FTM_ExistFiles + $FTM_Exist[$i] + " ";
						$FTM_ExistSubChecker = `checkBox -l ($FTM_ExistSize + " of them exist(s).") -al left
							-onc ("select -add " + $FTM_ExistFiles) -ofc ("if (" + $FTM_ExistSize + " > 0) select -deselect " + $FTM_ExistFiles)`;
						// A list of NOT exist files, which is used for selection.
						string $FTM_NotExistFiles = "";
						for ($i=0; $i<$FTM_NotExistSize; $i++)
							$FTM_NotExistFiles = $FTM_NotExistFiles + $FTM_NotExist[$i] + " ";
						$FTM_NotExistSubChecker = `checkBox -l ($FTM_NotExistSize + " of them NOT exist(s).") -al left
							-onc ("select -add " + $FTM_NotExistFiles) -ofc ("if (" + $FTM_NotExistSize + " > 0) select -deselect " + $FTM_NotExistFiles)`;
					setParent ($FTM_ParentUI + "|FTM_AnalysisCheckerColumn");
					// Main checker's onCommand and offCommand should influnce responding subcheckers in this case;
					checkBox -e -onc ("select -add " + $FTM_CurrentFiles + ";checkBox -e -v 1 -vis 0 " + $FTM_ExistSubChecker + ";checkBox -e -v 1 -vis 0 " + $FTM_NotExistSubChecker)
						-ofc ("if (" + $FTM_FilesStoredSize + " > 0) select -deselect " + $FTM_CurrentFiles + ";checkBox -e -v 0 -vis 1 " + $FTM_ExistSubChecker + ";checkBox -e -v 0 -vis 1 " + $FTM_NotExistSubChecker)
						$FTM_MainChecker;
				// Main checker's onCommand and offCommand should NOT influnce responding subcheckers in this case;
				else
					checkBox -e -onc ("select -add " + $FTM_CurrentFiles) -ofc ("if (" + $FTM_FilesStoredSize + " > 0) select -deselect " + $FTM_CurrentFiles) $FTM_MainChecker;
//Comand executed when Browse button pressed.
global proc FTM_BrowseCmd (string $FTM_FileOrPath, string $FTM_TextField, string $FTM_WhichButton, int $FTM_BrowseType)
//$FTM_FileOrPath		Pass to FTM_ChangeTextField
//$FTM_TextField		Pass to FTM_ChangeTextField
//$FTM_WhichButton		Pass to fileBrowser, which will be the label of the dialog
//$FTM_BrowseType		Pass to fileBrowser, which will define to get dialog for file or folder
	global string $FTM_WorkSpace;
	if (size($FTM_WorkSpace) == 0)
		$FTM_WorkSpace = `workspace -q -rd` + `workspace -q -rte "sourceImages"`;
		$FTM_WorkSpace = `FTM_GetPath "path" $FTM_WorkSpace`;
	workspace -dir $FTM_WorkSpace;
	global int $FTM_NEW_MAYA;
	if ($FTM_NEW_MAYA) { // use 'fileDialog2' for the browser command.
		if ($FTM_BrowseType == 0) $FTM_BrowseType = 1;
		else if ($FTM_BrowseType == 4) $FTM_BrowseType = 3;
		string $return[] = `fileDialog2 -ds 2 -cap $FTM_WhichButton -dir $FTM_WorkSpace -fm $FTM_BrowseType -okc $FTM_WhichButton -cc "Cancel"`;
		string $path = $return[0];
		if (!size($path)) $path = `textFieldButtonGrp -q -text $FTM_TextField`;
		if ($FTM_FileOrPath == "file") $path += "bugQuickFix";
		FTM_ChangeTextField $FTM_FileOrPath $FTM_TextField $path "";
	else {
		string $FTM_Temp = "";
			$FTM_Temp += "FTM_ChangeTextField ";
			$FTM_Temp += ("\"" + $FTM_FileOrPath + "\" ");
			$FTM_Temp += ("\"" + $FTM_TextField + "\" ");
		fileBrowser $FTM_Temp $FTM_WhichButton "" $FTM_BrowseType;
//The callback command on fileBrowser.
global proc FTM_ChangeTextField (string $FTM_FileOrPath, string $FTM_TextField, string $FTM_File, string $FTM_FileType)
//$FTM_FileOrPath	How to deal with the input path , will be pass to FTM_GetPath
//$FTM_TextField	The name of the control need to be edited
//$FTM_File			The file specified
//$FTM_FileType		The file type specified
	string $FTM_Path = `FTM_GetPath $FTM_FileOrPath $FTM_File`;
	textFieldButtonGrp -e -text (toNativePath($FTM_Path)) $FTM_TextField;
	//Close the dialog for IRIX/Linux.
	string $os = `about -os`;
	if (gmatch($os, "*irix*") || gmatch($os, "*linux*"))
		window -e -vis false projectViewerWindow;
	$FTM_WorkSpace = $FTM_Path;
// Reset the UI to its initial state.
global proc FTM_ResetUI (string $FTM_OptionColumn,string $FTM_AnalysisColumn,string $FTM_ExtraFunctionColumn,string $FTM_Tabs,string $FTM_CopyButton,string $FTM_MoveButton,string $FTM_SetButton)
	// The main window;
	global int $FTM_WIDTH, $FTM_HEIGHT;
	window -e -wh $FTM_WIDTH $FTM_HEIGHT FTM_MainWindow;
	// Analyse area
	text -e -l "Not analysed yet." ($FTM_AnalysisColumn + "|FTM_EmptyAnalysisText");
	if (`columnLayout -q -ex ($FTM_AnalysisColumn + "|FTM_AnalysisCheckerColumn")`)
		deleteUI ($FTM_AnalysisColumn + "|FTM_AnalysisCheckerColumn");
	// Operation mode
	radioButtonGrp -e -select 1 ($FTM_OptionColumn + "|FTM_OperationMode");
	// Source directory field
	textFieldButtonGrp -e -text "" -en 0 ($FTM_OptionColumn + "|FTM_SourceDirectoryField");
	// Target directory field
	string $FTM_CurrentProject = `workspace -q -rd`;
	string $FTM_CurrentSourceImagesDir = $FTM_CurrentProject + `workspace -q -rte "sourceImages"`;
	string $FTM_SourceImages = `FTM_GetPath "path" $FTM_CurrentSourceImagesDir`;
	textFieldButtonGrp -e -text $FTM_SourceImages ($FTM_OptionColumn + "|FTM_TargetDirectoryField");
	// Make new folder area
	checkBoxGrp -e -v1 0 ($FTM_OptionColumn + "|FTM_MakeFolderChecker");
	textFieldGrp -e -text "MyTextureFiles" -en 0 ($FTM_OptionColumn + "|FTM_NewFolderNameField");
	// Add prefix area
	checkBox -e -v 0 ($FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_AddPrefixChecker");
	textField -e -text "prefix_" -en 0 ($FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_PrefixField");
	// Add suffix area
	checkBox -e -v 0 ($FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_AddSuffixChecker");
	textField -e -text "_suffix" -en 0 ($FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_SuffixField");
	// Replace string area
	checkBoxGrp -e -v1 0 ($FTM_OptionColumn + "|FTM_ReplaceStringChecker");
	textFieldGrp -e -text "OldString" -en 0 ($FTM_OptionColumn + "|FTM_OldStringField");
	textFieldGrp -e -text "NewString" -en 0 ($FTM_OptionColumn + "|FTM_NewStringField");
	// Extra function tab
	textFieldButtonGrp -e -text "" ($FTM_ExtraFunctionColumn + "|oldRootField");
	string $tmp = `workspace -q -rd` + `workspace -q -rte "sourceImages"`;
	$tmp = `FTM_GetPath "path" $tmp`;
	textFieldButtonGrp -e -text $tmp ($FTM_ExtraFunctionColumn + "|newRootField");
	intFieldGrp -e -v1 1024 ($FTM_ExtraFunctionColumn + "|FTM_BOTRow|FTM_BOTResFieldGrp");
	intFieldGrp -e -v1 1024 ($FTM_ExtraFunctionColumn + "|FTM_MAPRow|FTM_MAPResFieldGrp");
	optionMenu -e -v "Mipmap" ($FTM_ExtraFunctionColumn + "|FTM_FilterTypeRow|FTM_FilterTypeMenu");
	optionMenu -e -v "\*" ($FTM_ExtraFunctionColumn + "|FTM_FCRow|FTM_FCSourceMenu");
	optionMenu -e -v "iff" ($FTM_ExtraFunctionColumn + "|FTM_FCRow|FTM_FCTargetMenu");
	checkBox -e -v 0 ($FTM_ExtraFunctionColumn + "|FTM_SeqCheck");
	checkBox -e -v 1 ($FTM_ExtraFunctionColumn + "|FTM_UpdateCheck");
	checkBox -e -v 0 -en 1 ($FTM_ExtraFunctionColumn + "|FTM_RemoveCheck");
	// Return to the first tab
	tabLayout -e -sti 1 $FTM_Tabs;
	// Reset all bottom function buttons
	button -e -en 1 $FTM_CopyButton;
	button -e -en 1 $FTM_MoveButton;
	button -e -en 1 $FTM_SetButton;
	select -cl;
// The Copy, Move and Set functions.
global proc FTM_Function (string $FTM_Function, string $FTM_OptionColumn)
	string $FTM_SelectedFiles[] = eval($lsCmd + " -sl");
	if (`FTM_SelCheck $FTM_SelectedFiles`)
		int $wrong = 0;
		// First get elements ready.
		int $FTM_OperationMode = `radioButtonGrp -q -select ($FTM_OptionColumn + "|FTM_OperationMode")`;
		// Source directory.
		string $FTM_SourceDirectory;
		// Target directory.
		string $FTM_TargetDirectory = `textFieldButtonGrp -q -text ($FTM_OptionColumn + "|FTM_TargetDirectoryField")`;
		$FTM_TargetDirectory = `FTM_GetPath "path" $FTM_TargetDirectory`;
		// Check if new folder needed. If needed, create one only when the folder does not exist.
		if ( `checkBoxGrp -q -v1 ($FTM_OptionColumn + "|FTM_MakeFolderChecker")` )
			string $FTM_NewFolderName = `textFieldGrp -q -text ($FTM_OptionColumn + "|FTM_NewFolderNameField")`;
			$FTM_TargetDirectory = $FTM_TargetDirectory + $FTM_NewFolderName;
			if (!`file -q -ex $FTM_TargetDirectory`) {
				if (`sysFile -md $FTM_TargetDirectory`)
					FTM_Log "" ("Folder created: \"" + (toNativePath($FTM_TargetDirectory)) + "\".") "";
				else {
					$wrong = 1;
					FTM_Log "" ("Folder can not be created: " + (toNativePath($FTM_TargetDirectory)) + "\".") "";
			else {
				if (!`filetest -w $FTM_TargetDirectory`) {
					$wrong = 1;
					FTM_Log "" ("Folder exists but is not writeable: " + (toNativePath($FTM_TargetDirectory)) + "\".") "";
		if (!$wrong) {
			// Define command for function.
			string $FTM_FunctionCmd;
			if ($FTM_Function == "Copy")
				$FTM_FunctionCmd = "sysFile -cp ";
			else if ($FTM_Function == "Move")
				$FTM_FunctionCmd = "sysFile -mov ";
			int $progress = 0;
			progressWindow -t "FTM Working..." -pr $progress -ii 1 -min 0 -max `size $FTM_SelectedFiles`;
			// Execute command of current function for every file texture node selected.
			for ($FTM_SelectedFile in $FTM_SelectedFiles)
				FTM_Log "" ($FTM_SelectedFile+":") "";
					break;
				$wrong = 0;
								$progress += 1;
				$percentage = $progress * (100/size($FTM_SelectedFiles));
				progressWindow -e -pr $progress -st ("Handling " + $FTM_SelectedFile + "     ......  " + $percentage + "%");
				// start to work
				string $FTM_CurrentFile = `getAttr ($FTM_SelectedFile + ".fileTextureName")`;
				string $FTM_SourceFile[] = `FTM_GetFile $FTM_CurrentFile`;
				string $FTM_OriginSourceFile = $FTM_SourceFile[1];
				// The file texture is not specified.
				if (size($FTM_OriginSourceFile) == 0)
					FTM_Log "" "" "WARNING: File texture is not specified.";
				// The file texture is specified.
				else
					// If replace string was selected, replace the string specified.
					if ( `checkBoxGrp -q -v1 ($FTM_OptionColumn + "|FTM_ReplaceStringChecker")` )
						string $FTM_OldString = `textFieldGrp -q -tx ($FTM_OptionColumn + "|FTM_OldStringField")`;
								$FTM_OldString = `substituteAllString $FTM_OldString $char ("\\"+$char)`;
						string $FTM_MatchExpression = "(" + $FTM_OldString + ")+";
						string $FTM_NewString = `textFieldGrp -q -tx ($FTM_OptionColumn + "|FTM_NewStringField")`;
						for ($i=0; $i<size($FTM_SourceFile[1]); $i++)
							$FTM_SourceFile[1] = `substitute $FTM_MatchExpression $FTM_SourceFile[1] $FTM_NewString`;
					// Add prefix or(and) append suffix.
					string $FTM_Prefix;
					string $FTM_Suffix;
					string $FTM_SourceFileRegularName[] = `FTM_FCFileRegularName $FTM_SourceFile[1]`;
					// If prefix was set, add it to the file name.
					if ( `checkBox -q -v ($FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_AddPrefixChecker")` )
						$FTM_Prefix = `textField -q -tx ($FTM_OptionColumn + "|FTM_AddPrefixRow|FTM_PrefixField")`;
					// If suffix was set, append it to the file name.
					if ( `checkBox -q -v ($FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_AddSuffixChecker")` )
						$FTM_Suffix = `textField -q -tx ($FTM_OptionColumn + "|FTM_AddSuffixRow|FTM_SuffixField")`;
					// Assemble the filename
					if (size($FTM_SourceFileRegularName[1]))
						$FTM_SourceFileRegularName[1] = "." + $FTM_SourceFileRegularName[1];
					if (size($FTM_SourceFileRegularName[2]))
						$FTM_SourceFileRegularName[2] = "." + $FTM_SourceFileRegularName[2];
					$FTM_SourceFile[1] = $FTM_Prefix + $FTM_SourceFileRegularName[0] + $FTM_Suffix + $FTM_SourceFileRegularName[1] + $FTM_SourceFileRegularName[2];
					// Function process.
					string $FTM_FinalCmd;
					string $FTM_FunctionResult;
					int $setWrong = 0;
					if ($FTM_Function != "Set")
						if ($FTM_OperationMode == 1)
							$FTM_FinalCmd = $FTM_FunctionCmd + "\"" + `substituteAll "\\\\" ($FTM_TargetDirectory + $FTM_SourceFile[1]) "/"` + "\" \"" + `substituteAll "\\\\" $FTM_SourceFile[0] "/"` + "\"";
							$FTM_FunctionResult = $FTM_Function + " \"" + `toNativePath $FTM_SourceFile[0]` + "\" to \"" + `toNativePath ($FTM_TargetDirectory + $FTM_SourceFile[1])` + "\". ";
						else if ($FTM_OperationMode == 2)
							$FTM_SourceDirectory = `textFieldButtonGrp -q -text ($FTM_OptionColumn + "|FTM_SourceDirectoryField")`;
							$FTM_SourceDirectory = `FTM_GetPath "path" $FTM_SourceDirectory`;
							$FTM_FinalCmd = $FTM_FunctionCmd + "\"" + `substituteAll "\\\\" ($FTM_TargetDirectory + $FTM_SourceFile[1]) "/"` + "\" \"" + `substituteAll "\\\\" ($FTM_SourceDirectory + $FTM_OriginSourceFile) "/"` + "\"";
							$FTM_FunctionResult = $FTM_Function + " \"" + `toNativePath ($FTM_SourceDirectory + $FTM_OriginSourceFile)` + "\" to \"" + `toNativePath ($FTM_TargetDirectory + $FTM_SourceFile[1])` + "\". ";
					else if ($FTM_Function == "Set")
						string $path = `substituteAll "\\\\" ($FTM_TargetDirectory + $FTM_SourceFile[1]) "/"`;
						string $cmd = "setAttr -typ \"string\" " + $FTM_SelectedFile + ".fileTextureName \"" + $path + "\"";
						if (catchQuiet(eval($cmd))) {
							$FTM_FunctionResult = "Attribute \"fileTextureName\" is locked/connected and can NOT be modified!";
							$setWrong = 1;
						else
							$FTM_FunctionResult = "Set to \"" + `toNativePath ($FTM_TargetDirectory + $FTM_SourceFile[1])` + "\". ";
					// Do the function.
					if ($FTM_Function != "Set") {
						if (!eval($FTM_FinalCmd)) {
							$wrong = 1;
							FTM_Log "" "" ("WARNING: " + $FTM_Function + " can NOT be done, could be permission issue or path existence issue.");
					if (!$wrong) {
						// Print the function result.
						if ( `file -q -ex ($FTM_TargetDirectory + $FTM_SourceFile[1])` )
								// File copied but not removed -- not actually "move".
								if ( `file -q -ex $FTM_SourceFile[0]` || `file -q -ex ($FTM_SourceDirectory + $FTM_OriginSourceFile)`)
									$FTM_FunctionResult = "Succeed: " + $FTM_FunctionResult + " But the original file is not removed. Check the HELP for possible reasons.";
									FTM_Log "" "" ("WARNING: " + $FTM_FunctionResult);
								else
									$FTM_FunctionResult = "Succeed: " + $FTM_FunctionResult;
									FTM_Log "" "" $FTM_FunctionResult;
							else
						else
							if ($FTM_Function == "Set") {
								if ($setWrong)
									$FTM_FunctionResult = "WARNING: " + $FTM_FunctionResult;
								else
									$FTM_FunctionResult = "Succeed: " + $FTM_FunctionResult + "But destination does NOT exist.";
							else if ($FTM_Function != "Set")
								$FTM_FunctionResult = "Fail: " + $FTM_FunctionResult + "Check Help tab for possible reasons.";
		progressWindow -ep;
		// job done
		FTM_END;
//Build the main UI.
global proc FileTextureManager_2018 ()
// Version Check
float $verCut = 2010;
global int $FTM_NEW_MAYA, $FTM_WIDTH, $FTM_HEIGHT;
$FTM_NEW_MAYA = 0;
$FTM_WIDTH = 380;
$FTM_HEIGHT = 600;
string $verString = `about -v`;
string $verString_tmp[];
tokenize $verString " " $verString_tmp;
float $verNum = $verString_tmp[0];
if ($verNum > $verCut) { // version newer than 2010
	$FTM_NEW_MAYA = 1;
	$FTM_WIDTH = 520;
	$FTM_HEIGHT = 700;
// array of formats supported by format conversion function
$FTM_FCAllFormats = {"iff","sgi","tga","rgb","jpg","jpeg","map","tif","tiff","bmp","bw","icon","cin","pic","yuv","als","gif","lff","pxb","scn","ppm","pri","qtl","vst","rla"};
// cover all file texture nodes including mentalray's
$lsCmd = "ls -typ file -typ psdFileTex -typ file";
select -cl;
global string $FTM_MayaWorkSpace;
$FTM_MayaWorkSpace = `workspace -q -dir`;
global string $FTM_WorkSpace = "";
//Make sure the window will be displayed in proper size.
windowPref -enableAll false;
//If the UI exits , delete it.
if (`window -exists FTM_MainWindow`)
	deleteUI FTM_MainWindow;
//Build a new UI.
window -title "File Texture Manager" -wh $FTM_WIDTH $FTM_HEIGHT -tlc 200 200 -ret FTM_MainWindow;
	string $FTM_MainForm = `formLayout`;
		string $FTM_Tabs = `tabLayout -imw 0 -imh 0`;
//Option tab
		string $FTM_OptionForm = `formLayout`;
			string $FTM_OptionScroll = `scrollLayout -cr true`;
			string $FTM_OptionColumn = `columnLayout -adj 1 -rs 5`;
//Analyse area
				formLayout -nd 100 FTM_AnalyseForm;
						string $FTM_AnalyseColumn = `columnLayout -cat both 30 -adj 1 -rs 5`;
							button -l "Analyse Scene File Textures" -h 30 -w 250 FTM_AnalyseButton;
							text -l "" -h 5;
							text -l "Select files you want to manage. <Multi-Selectable>";
						string $FTM_AnalysisScroll = `scrollLayout -p FTM_AnalyseForm`;
							string $FTM_AnalysisColumn = `columnLayout -cat left 15`;
								text -l "Not analysed yet." FTM_EmptyAnalysisText;
							button -e -c ("FTM_AnalyseFileTextures " + $FTM_AnalysisColumn) ($FTM_AnalyseColumn + "|FTM_AnalyseButton");
				formLayout -e
					-af $FTM_AnalyseColumn left 0
					-af $FTM_AnalyseColumn right 0
					-af $FTM_AnalyseColumn top 5
					-af $FTM_AnalyseColumn bottom 200
					-ac $FTM_AnalysisScroll top 5 $FTM_AnalyseColumn
					-af $FTM_AnalysisScroll bottom 0
					-af $FTM_AnalysisScroll left 0
					-af $FTM_AnalysisScroll right 0
					($FTM_OptionColumn + "|FTM_AnalyseForm");
			setParent $FTM_OptionColumn;
				separator -style "in" -h 10;
//Operation mode
				radioButtonGrp -l "Operation Mode" -la2 "Automatic" "Manual" -nrb 2 -select 1 -cl3 right left left -cw3 120 100 100 FTM_OperationMode;
				separator -style "in" -h 5;
//Set source directory area
				textFieldButtonGrp -label "Source Directory" -text "" -buttonLabel "Browse..." -adj 2 -en 0 -cw 1 120 -cw 3 60 -cl3 right left center FTM_SourceDirectoryField;
//Set target directory area
				textFieldButtonGrp -label "Target Directory" -text $FTM_SourceImages -buttonLabel "Browse..." -adj 2 -cw 1 120 -cw 3 60 -cl3 right left center FTM_TargetDirectoryField;
//Create new folder area
				checkBoxGrp -ncb 1 -l1 "Make New Folder Under Target Directory" -adj 1 -v1 0 -cat 1 left 101 FTM_MakeFolderChecker;
				textFieldGrp -label "Folder Name" -text "MyTextureFiles" -en 0 -cw2 120 180 -cl2 right left FTM_NewFolderNameField;
				text -al center -l "The FINAL target directory will be equal to target directory";
				text -al center -l "plus the new folder if user decide to make a new folder";
//Update texture file area
				rowLayout -nc 2 -cw 1 120 -cat 1 right 0 -cl2 left left FTM_AddPrefixRow;
					checkBox -l "Add Prefix" -v 0 FTM_AddPrefixChecker;
					textField -tx "prefix_" -en 0 -w 150 FTM_PrefixField;
				rowLayout -nc 2 -cw 1 120 -cat 1 right 0 -cl2 left left FTM_AddSuffixRow;
					checkBox -l "Add Suffix" -v 0 FTM_AddSuffixChecker;
					textField -tx "_suffix" -en 0 -w 150 FTM_SuffixField;
				checkBoxGrp -ncb 1 -l1 "Replace String" -adj 1 -v1 0 -cat 1 left 101 FTM_ReplaceStringChecker;
				textFieldGrp -l "Old String" -tx "OldString" -en 0 -cw2 120 150 -cl2 right left FTM_OldStringField;
				textFieldGrp -l "New String" -tx "NewString" -en 0 -cw2 120 150 -cl2 right left FTM_NewStringField;
		formLayout -e
			-af $FTM_OptionScroll top 5
			-af $FTM_OptionScroll left 0
			-af $FTM_OptionScroll right 0
			-af $FTM_OptionScroll bottom 0
			$FTM_OptionForm;
		setParent $FTM_Tabs;
//Extra function tab
			string $FTM_ExtraFunctionScroll = `scrollLayout -cr true`;
			string $FTM_ExtraFunctionColumn = `columnLayout -cat both 15 -adj 1 -rs 5`;
				// Substitute path root area
				separator -style "none" -h 5;
				text -fn "boldLabelFont" -al left -l "Substitute path root";
				textFieldButtonGrp -l "Old Root" -text "" -buttonLabel "Browse..." -adj 2 -en 1 -cw 1 80 -cw 3 60 -cl3 right left center oldRootField;
				textFieldButtonGrp -e -bc ("FTM_BrowseCmd \"path\" " + $FTM_ExtraFunctionColumn + "|oldRootField \"Choose old root\" 4") ($FTM_ExtraFunctionColumn + "|oldRootField");
				textFieldButtonGrp -l "New Root" -text $tmp -buttonLabel "Browse..." -adj 2 -en 1 -cw 1 80 -cw 3 60 -cl3 right left center newRootField;
				textFieldButtonGrp -e -bc ("FTM_BrowseCmd \"path\" " + $FTM_ExtraFunctionColumn + "|newRootField \"Choose new root\" 4") ($FTM_ExtraFunctionColumn + "|newRootField");
				button -h 25 -l "Substitute" -c ("FTM_Substitute " + $FTM_ExtraFunctionColumn + "|oldRootField " + $FTM_ExtraFunctionColumn + "|newRootField");
				// BOT setup area
				text -fn "boldLabelFont" -al left -l "Memory Efficiency (Maya 'file' nodes only)";
				//text -fn "boldLabelFont" -al left -l "BOT Setup (Maya sw renderer only)";
				text -al left -l "\"BOT\" Setup (Maya sw renderer only)";
				rowLayout -nc 3 -adj 3
						-cw 1 170 -cw 2 2 -cal 3 center
						-cat 1 both 0 -cat 3 both 0
						-rat 1 bottom 0 -rat 2 bottom 0 -rat 3 bottom 0
						FTM_BOTRow;
					intFieldGrp -nf 1 -adj 2 -cw 1 50 -cat 1 left 0 -cat 2 both 5 -l "Threshold" -el "" -v1 1024 FTM_BOTResFieldGrp;
					text -l "";
					button -h 25 -l "Setup BOT" -c ("FTM_BOTSetup 1 " + $FTM_ExtraFunctionColumn);
				setParent ..;
				button -h 25 -l "Unset BOT" -c ("FTM_BOTSetup 0 " + $FTM_ExtraFunctionColumn);
				text -al left -l "\".map\" Setup (mentalray only)";
						FTM_MAPRow;
					intFieldGrp -nf 1 -adj 2 -cw 1 50 -cat 1 left 0 -cat 2 both 5 -l "Threshold" -el "" -v1 1024 FTM_MAPResFieldGrp;
					text -l "";
					button -h 25 -l "Setup .map" -c ("FTM_MAPSetup 1 " + $FTM_ExtraFunctionColumn);
				setParent ..;
				button -h 25 -l "Unset .map" -c ("FTM_MAPSetup 0 " + $FTM_ExtraFunctionColumn);
				// Filter setup area
				text -fn "boldLabelFont" -al left -l "Filter setup (Maya 'file'/'psdFileTex' nodes only)";
				rowLayout -nc 2 -cw 1 120 -cat 2 left 30 -adj 2 -cal 2 center -rat 1 bottom 0 FTM_FilterTypeRow;
					optionMenu -l "Filter Type" FTM_FilterTypeMenu;
							menuItem -label "Off";
							menuItem -label "Mipmap";
							menuItem -label "Box";
							menuItem -label "Quadratic";
							menuItem -label "Quartic";
							menuItem -label "Gaussian";
					button -h 25 -l "Set Filter Type" -c ("FTM_FilterSetup " + $FTM_ExtraFunctionColumn);
				setParent ..;
				// Format conversion area
				text -fn "boldLabelFont" -al left -l "Texture file format conversion";
				rowLayout -nc 3	-cw 1 80 -cw 3 80 -cat 1 left 0 -cat 2 left 10 -cat 3 left 10 -adj 2 -cal 2 center FTM_FCRow;
					optionMenu -l "From" FTM_FCSourceMenu;
						menuItem -label "\*";
						for ($i=0;$i<size($FTM_FCAllFormats);$i++)
							menuItem -label $FTM_FCAllFormats[$i];
					button -h 25 -l "Select Matches" -c ("select -r `FTM_FCGetMatches \"" + $FTM_ExtraFunctionColumn + "|FTM_FCRow|FTM_FCSourceMenu\"`;");
					optionMenu -l "To" FTM_FCTargetMenu;
				setParent ..;
				checkBox -l "Handle sequence textures." -al "left" -v 0 FTM_SeqCheck;
				checkBox -l "Update path info." -al "left" -v 1 FTM_UpdateCheck;
				checkBox -l "Remove original textures. Use with caution!" -al "left" -v 0 -en 1 FTM_RemoveCheck;
				checkBox -e -onc ("checkBox -e -en 1 " + $FTM_ExtraFunctionColumn + "|FTM_RemoveCheck")
							-ofc ("checkBox -e -en 0 " + $FTM_ExtraFunctionColumn + "|FTM_RemoveCheck")
				button -l "Convert" -h 25 -c ("FTM_FCGatherInfo " + $FTM_ExtraFunctionColumn);
//Help tab
			string $FTM_HelpForm = `formLayout`;
//Description area
				scrollField -ww true -editable false FTM_HelpField;
//About FileTextureManager_2018
			setParent $FTM_HelpForm;
				string $FTM_AboutFrame;
				if ($FTM_NEW_MAYA) $FTM_AboutFrame = `frameLayout -l "About FileTextureManager_2018" -fn boldLabelFont -cll 0 -bv true -bs "in" -li 5`;
				else $FTM_AboutFrame = `frameLayout -l "About FileTextureManager_2018" -la top -fn boldLabelFont -cll 0 -bv true -bs "in" -li 5`;
				string $FTM_AboutForm = `formLayout`;
					string $FTM_AboutTextLeft = `text -l "Script Name :\nUpdated :\nAuthor :\nContact :\n\nAll  Rights  Reserved." -al left`;
					string $FTM_AboutTextRight = `text -l "FileTextureManager_2018.mel\nMay, 2011\nCrow Yeh ( YE Feng )\[email protected]" -al left`;
				formLayout -e
					-af $FTM_AboutTextLeft left 10
					-af $FTM_AboutTextLeft top 5
					-an $FTM_AboutTextLeft right
					-af $FTM_AboutTextLeft bottom 5
					-ac $FTM_AboutTextRight left 10 $FTM_AboutTextLeft
					-af $FTM_AboutTextRight top 5
					-an $FTM_AboutTextRight right
					-an $FTM_AboutTextRight bottom
					$FTM_AboutForm;
			formLayout -e
				-ac FTM_HelpField bottom 5 $FTM_AboutFrame
				-af FTM_HelpField top 5
				-af FTM_HelpField left 0
				-af FTM_HelpField right 0
				-an $FTM_AboutFrame top
				-af $FTM_AboutFrame left 0
				-af $FTM_AboutFrame right 0
				-af $FTM_AboutFrame bottom 0
				$FTM_HelpForm;
//Function form.
	setParent $FTM_MainForm;
		string $FTM_FunctionForm = `formLayout -h 30 -numberOfDivisions 100`;
			string $FTM_CopyButton = `button -l "Copy Files"
							-c ("FTM_Function \"Copy\" " + $FTM_OptionColumn)`;
			string $FTM_MoveButton = `button -l "Move Files"
							-c ("FTM_Function \"Move\" " + $FTM_OptionColumn)`;
			string $FTM_SetButton = `button -l "Set Path"
							-c ("FTM_Function \"Set\" " + $FTM_OptionColumn)`;
			string $FTM_ResetButton = `button -l "Reset FTM" -c ("FTM_ResetUI "+$FTM_OptionColumn+" "+$FTM_AnalysisColumn+" "+$FTM_ExtraFunctionColumn+" "+$FTM_Tabs+" "+$FTM_CopyButton+" "+$FTM_MoveButton+" "+$FTM_SetButton)`;
			string $FTM_CloseButton = `button -l "Exit"
							-c ("deleteUI FTM_MainWindow; select -cl;global string $FTM_MayaWorkSpace; workspace -dir $FTM_MayaWorkSpace;")`;
		formLayout -e
			-ap $FTM_CopyButton right 1 20
			-af $FTM_CopyButton top 0
			-af $FTM_CopyButton left 0
			-af $FTM_CopyButton bottom 0
			-ap $FTM_MoveButton left 1 20
			-ap $FTM_MoveButton right 1 40
			-af $FTM_MoveButton top 0
			-af $FTM_MoveButton bottom 0
			-ap $FTM_SetButton left 1 40
			-ap $FTM_SetButton right 1 60
			-af $FTM_SetButton top 0
			-af $FTM_SetButton bottom 0
			-af $FTM_ResetButton top 0
			-af $FTM_ResetButton bottom 0
			-ap $FTM_ResetButton left 1 60
			-ap $FTM_ResetButton right 1 80
			-ap $FTM_CloseButton left 1 80
			-af $FTM_CloseButton top 0
			-af $FTM_CloseButton right 0
			-af $FTM_CloseButton bottom 0
			$FTM_FunctionForm;
	formLayout -e
		-af $FTM_Tabs top 0
		-af $FTM_Tabs left 0
		-af $FTM_Tabs right 0
		-ac $FTM_Tabs bottom 3 $FTM_FunctionForm
		-af $FTM_FunctionForm left 0
		-af $FTM_FunctionForm right 0
		-af $FTM_FunctionForm bottom 0
		-an $FTM_FunctionForm top
		$FTM_MainForm;
FTM_EditUIControl $FTM_OptionColumn $FTM_HelpForm;
string $tabCC = "button -e -en 0 " + $FTM_CopyButton + ";";
$tabCC += "button -e -en 0 " + $FTM_MoveButton + ";";
$tabCC += "button -e -en 0 " + $FTM_SetButton + ";";
$tabCC += "if (`tabLayout -q -sti " + $FTM_Tabs + "` == 1) {";
$tabCC += "button -e -en 1 " + $FTM_CopyButton + ";";
$tabCC += "button -e -en 1 " + $FTM_MoveButton + ";";
$tabCC += "button -e -en 1 " + $FTM_SetButton + ";";
$tabCC += "}";
tabLayout -e -tl $FTM_OptionForm "BasicFunctions" -tl $FTM_ExtraFunctionScroll "ExtraFunctions" -tl $FTM_HelpForm "Help" -psc $tabCC $FTM_Tabs;
showWindow FTM_MainWindow;
//Make sure other windows will be displayed in proper size.
windowPref -enableAll true;
// SCRIPT Ends //
Appreciate your solution , but I am really interested in solving this myself hence the specific questions.
jordan.giboney
Hi @Anonymous
Thanks for posting! I believe @rajasekaransurjen has the right idea. I pulled this from his post:
import maya.cmds as cmds
list = cmds.ls(type='file')
for node in list:
print cmds.getAttr(node+'.fileTextureName')
Also, fileTextureName is a string, so you can use Python string operations like replace
or regular expressions 🙂
Please let me know if that helps! I would be happy to assist as needed.
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
@jordan.giboney yeap i think this is what i need thanks.
