Render Setup commands documentation
InvisioMedia
Message 1 of 8
InvisioMedia
  I think some better documentation is now needed on the render setup commands.  Just writing help() with the module is absolutely not helping me, the API is obscure and the docstrings are barely readable for me..
  The MASH Api documentation pages are super well made and should be taken as a model to follow if I can suggest:
https://help.autodesk.com/cloudhelp/2018/ENU/Maya-Tech-Docs/MASH/MASH.html
  That being said, how can I create a material override in python, associated with a collection?  I have been able to create my layer and collection but spent the day wandering without being able to do it.  I know what type nodeType 'materialOverride' is, but it seems it's useless to know this in this situation, it doesn't appear anywhere in the node editor...  No way to get hints with the Echo All function of the script editor neither.
  Thanks for your help!!
Replies (7)
Message 2 of 8
lanh.hong
The docs for the Render Setup Python API can be found here:
http://help.autodesk.com/view/MAYAUL/2019/ENU//?guid=GUID-FFC3298A-9803-4EAF-B472-D13247319EB0
The API is unsupported and does not have any official documentation. What usually will help is to look at the Python files located in ..\Python\Lib\site-packages\maya\app\renderSetup.
Here's a sample on how to create a material override.
import maya.app.renderSetup.model.renderSetup as renderSetup
rs = renderSetup.instance()
# Create render layer and collection
rl = rs.createRenderLayer("MyRenderSetupLayer")
c = rl.createCollection("MyCollection")
# Create material override
materialOverride = c.createOverride("MyMaterialOverride", "materialOverride")
Lanh
Lanh Hong
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
lanh.hong
BTW createOverride method can be found in ..\Python\Lib\site-packages\maya\app\renderSetup\model\collection.py
Lanh Hong
Message 4 of 8
InvisioMedia
Yes that's perfect, thank you so much.  Indeed, it's impossible to know what argument is expected in createOverride() with only the help() python function (the doc strings suggested by the maya help).  It took me 2 days to find this simple line of command, a little bit frustrating...
I should be good with the "\Python\Lib\site-packages\maya\app\renderSetup\model", thank you!  Some documentation would be welcomed, it's not very intuitive to dig in the maya installation python scripts for documentation and help.
Message 5 of 8
Sigrid.mohn
agree that some more documentation could be handy I keep hitting a wall in what I would think should be super simple. Currently I am struggling with renaming already created render layers..
Message 6 of 8
bdewalleDD7LQ
I strongly agree. The link provided above (https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Maya-Ren...) is not a documentation but a set of exemples.
A lot of stuff are not covered, and we should not have to retro - engineer maya api methods...
Message 7 of 8
wrenA5JDC
Observer
Observer
Does anyone happen to have the Command to add a Render Settings Collection for all the overrides in the globals? I'm trying to create a custom python that will create a render layer that will contain specific Absolute render overrides for things like min and max samples.
Message 8 of 8
sschierwater
The current RenderSetup was introduced in Maya 2016 if i remember correctly... 10 years later you would think there would be a official API documentation...
Quite frustrating as it makes development unnecessarily harder
