Rename objects according to parent's name
lauris4747
lauris4747
maybe someone could help me to rename selected objects and their children.
I want to export many objects using FBX to Unity. Unity recognises LOD (Level of detail) according to the naming.
Each LOD should be within the original model.
I have around 2000 objects, some of them have 2 children, some of them have 1.
The naming should be according to parent's name + _LOD + depth. Lets say parent is Object1 so the naming should be:
Object1_LOD0 - Parent object
   Object1_LOD1 - First child object
      Object1_LOD2- Second child object
 Object2_LOD0
    Object2_LOD1
 Object3_LOD0
    Object3_LOD1
          Object3_LOD2
etc...
I hope someone can help. Thank you.
viru.gupta8
# select your all parent object or get list of them. allParentObjects = cmds.ls(sl=True) for object in allParentObjects: dag_obj = cmds.listRelatives(object, ad=True, type="transform") #gives you all child objects objectsToRename = [object]+dag_obj #list parent then child for num, obj in enumerate(objectsToRename): cmds.rename(obj, obj+"_LOD"+str(num))
I think That will do your Job.
lauris4747
Thank you very much!
