Remove the # character when using python logging
Hi!
We are trying to use the regular python logging instead of using prints.
I am using the maya.utils.MayaGuiLogHandler() as handler.
But any formatter I use, there is no way to get rid of the # in the script editor.
import logging
handler = maya.utils.MayaGuiLogHandler()
firstHandler = logger.handlers[0]
logger.addHandler(handler)
logger.removeHandler(firstHandler)
logger.propagate=False
logging.info("test")
Result is
# test #
How can I get rid of the #s ??
using
handler = logging.StreamHandler(sys.stdout)
Remove the # at the beginning of the log.
But I lost the behavior of
that displays in the correct color in the Maya GUI
cheng_xi_li
Autodesk Support
Autodesk Support
I think you can't remove the '#' with default logging handler. However, you can write your own handler, there is a template inside the pymel devkit folder(devkit\other\pymel\extras\completion\py\maya\utils.py) where you could start.
Yours,
Li
Hi Li!
Thanks for the answer.
The # was printed because it seems that the default logging stream is stderr in Maya.
Using stdout instead is working ok to remove the #.
Now, I just want to be able to set color in the status line (without using the MGlobal.error or MGlobal.warning)
Do you have any idea how to do it?
ANd I will use my own handler
cheng_xi_li
Autodesk Support
Autodesk Support
In that case, I don't think Maya have a command or API for that. Sorry about that.
Yours,
Li
I will try to find a way then
