redo action duplicates shapes
Message 1 of 12
I implemented a MPxCommand and try to add proper undo/redo support to it. Now I have the problem, that the redo function duplicates the actions.
Minimal example:
MStatus myCmd::doIt(const MArgList &args) {
    return redoIt()
MStatus myCmd::redoIt() {
    dagMod.createNode("mesh");
    dagMod.doIt();
    return MStatus::kSuccess;
MStatus myCmd::undoIt() {
    dagMod.undoIt();
bool MyCmd::isUndoable() const {
return true;
with MDagModifier dagMod as private member of the command class.
Is there some kind of .clear() function I need to call to make sure I do not add commands twice to dagMod? I thought undoIt will clear the action stack, but after each undo/redo I get one more shape than before.
Replies (11)
Message 2 of 12
When I try
if(done) {
    dagMod.doIt();
dgMod.doIt(); } else { done = true; }
It works with dagMod only, leaving my node (not in the minimal example above) behind. When dgMod is added I get the problem again.
Message 3 of 12
cheng_xi_li
Autodesk Support
Autodesk Support
Maya will call redoIt when redo command.
Thus, redoIt and doIt should be like this
MStatus myCommand::doIt(const MArgList& list){
	dagModifier.createNode("mesh");
	dagModifier.doIt();
        return MS::kSuccess;
MStatus myCommand::redoIt(){
       dagModifier.doIt();
You don't have to clear it at all, just call doIt again and it will work.
Yours,
Li
Message 4 of 12
I tried putting doIt into redoIt, but I had problems constructing the same data. I guess because I have a dagModifier and a dgModifier and call dagMod.doIt in the middle to create an object which can be connected to other nodes.
When I tried to run code with dagMod.doIt and dgMod.doIt in my doIt function and just run dagMod.doIt/dgMod.doIt in my redo function I still got DGNodes left.
I am not sure if i need to call undoIt/doIt on both Modifiers one time for each doIt in the right order or if I need to restructure the code to be able to have just one doIt call.
I currently implemented undoIt now by deleting the nodes, but I think this may damage the undo history as well.
Message 5 of 12
cheng_xi_li
Autodesk Support
Autodesk Support
Why are you using both MDGModifier and MDagModifier at the same time?
MDagModifier inherits MDGModifier it doesn't make sense to me.
Yours,
Li
Message 6 of 12
I thought you should always use DGModifier when you're using Dependencynodes which are not in the DAG. Something like the DG allowing circular connections while the DAG does not or similar. So I should just use a DagModifier? I'll try.
Message 7 of 12
cheng_xi_li
Autodesk Support
Autodesk Support
OK. I see your point. It should be separated. Let me try with your method now.
Yours,
Li
Message 8 of 12
cheng_xi_li
Autodesk Support
Autodesk Support
MStatus nodeInfo::doIt( const MArgList& args )
	dgModifier.createNode("lambert");
	dagModifier.doIt();
	dgModifier.doIt();
MStatus nodeInfo::redoIt()
	dagModifier.doIt();
	dgModifier.doIt();
MStatus nodeInfo::undoIt()
	dgModifier.undoIt();
	dagModifier.undoIt();
It is working fine, you'll need to call undoIt for both modifier. It also should be in order to prevent potential issues.
Yours,
Li
Message 9 of 12
This does not work for me.
my doIt only reads some input which should stay constant during undo/redo, then I call redoIt. I guess this should be fine.
In redoIt I create and rename Nodes and then apply this with the dagMod to connect them with the dgMod later.
The relevant pieces are mostly
undoIt:
        dagMod.undoIt();
        dgMod.undoIt();
doIt
	MStatus status;
	status = MGlobal::getActiveSelectionList(selList);
	return redoIt();
redoIt
        MObject offsetMeshTransform = dagMod.createNode("transform");
        MObject offsetMesh = dagMod.createNode("mesh", offsetMeshTransform);
        dagMod.renameNode(offsetMeshTransform, "offsetMesh");
        dagMod.renameNode(offsetMesh, "offsetMeshShape");
        dagMod.doIt();
        MObject extractNode = dgMod.createNode(flatOffsetExtractNode::id);
        dgMod.connect(extractNodeOutOffsetMeshPlug, offsetInMeshPlug);
        while(!it.isDone()) {
                // some code to get the plugs
                dgMod.connect(worldMeshPlug, myInMeshPlug);
        dgMod.doIt();
 offsetMesh and extractNode need to be removed on undo and created again on redo. Currently they get deleted on undo but redo acts like it would both redo and execute the command again. This means when I undo/redo three times, I got four nodes and four meshes.
Another undo then removes all four, so this seems to work, just the next doIt seems to have the old operations still on the stack.
Message 10 of 12
cheng_xi_li
Autodesk Support
Autodesk Support
Are you still having createNode inside of redoIt? It should just have MDG/MDagModifier:doIt. All createNode or connecting code should be inside MPxCommand::doIt.
When Maya first executes ab undoable command, it will create a new MPxCommand and call doIt, then put it in the undo queue.
When it undos, Maya will find the latest command call undoIt.
When it redos, Maya will call its redoIt. So if you add all dg/dag action in redo it, you are adding it again when redoing the command. Because Maya will always call redoIt instead doIt. So, the correct way here is putting all dg related code inside doIt and just call MDG/MDagModifier::doIt inside redoIt to reuse previous dg/dag modifiers.
If you have already done that and it still doesn't work, could you let me have a look at a working sample code?
Yours,
Li
Message 11 of 12
Yes, I create them in redoIt. Sounds like that's the problem. I thought the main code should go into redoIt, like a node should do everything in compute.
I think try to isolate the createNode code into doIt and put the computation in redoIt then.
Message 12 of 12
I create the node and mesh in doIt and the rest is computed in redoIt. Seems to work fine now. Thank you.
