Random Select Objects in Group by Percentage in Mel?
victorbennett
victorbennett
Can someone help me figure out how to write out a way to randomly select objects that are in a group by a percentage in Mel?  I need to embed this into another script I'm making.
Thanks!
Vic
mcw0
string $objects[] = `listRelatives -type "transform" -pa "yourGroup"`;  //  FIRST GET OBJECTS IN GROUP
int $num = size($objects);  //  NUMBER OF OBJECTS
float $percent = 50.0;  //  NOW SET YOUR PERCENTAGE OF OBJECTS TO SELECT
int $numToSelect = ($percent/100.0) * $num;  //  ACTUAL NUMBER OF OBJECTS TO SELECT
//  USE A RANDOM NUMBER FUNCTION TO DETERMINE IF AN OBJECT IS SELECTED OR NOT
float $threshold = $percent/100.0;  //  SINCE THIS EXAMPLE USES 50%, A THRESHOLD OF .5 IS USED
string $list[];  //  RECORD THE OBJECTS TO SELECT
while(size($list) < $numToSelect)  //  KEEP SELECTING UNTIL DESIRED PERCENTAGE IS ACHIEVED
    for($object in $objects)  //  LOOP THROUGH YOUR OBJECTS TO DETERMINE WHICH ARE SELECTED
        if(rand(1) > $threshold)
            $list[size($list)] = $object;
    $objects = stringArrayRemove($list, $objects);  //  REMOVE SELECTED OBJECTS FROM YOUR ORIGINAL LIST
This was typed without trying it in Maya.  But the logic is there.  And I'm pretty sure it will work.  Using a "while" conditional is always hazardous, but in this case, you will eventually hit your percentage so it shouldn't go into an endless loop.  Good luck.
victorbennett
Thanks!  However, it's not selecting anything and I'm not getting any errors...
Vic
mcw0
I'm so sorry.  I forgot the last line!!!
select -r $list;
victorbennett
Works great.  Thanks!
shmelov
Community Visitor
Community Visitor
This topic made my day. Many thanks to autor, and especialy to mcw0. That script solved a big problem for me!
victorbennett
So glad it helped!
