Announcements
Query Xform at certain time?
A simple question here,
we wrote a script that samples the worldspace Xform position based on a frame range using the cmds.currentTime command to indicate the frame we want to sample.
all works well, but we are looking for a way to speed up the sampling so we can skip the viewport evaluation for every frame and still sample the correct values.
in other words we are looking for a 'time' atribute in the x form command 🙂
what would be the easyest way around this problem?
thanks.
Tristan
Shkval3d
Hi there.
I use c++ API for it...
but you can write it on Python too, I guess
 MStatus WrightBoneAnim(MDagPath &bonePath, MMatrixArray &mArr, int sf, int ef) // sf - start frame, ef - end frame
{        // mArr - array of matrices for object
// in given time range MStatus status; mArr.clear(); MTime time_1; time_1.setUnit(MAnimControl::currentTime().unit()); for (int i = sf; i <= ef; i++) { time_1.setValue(i); status = MAnimControl::setCurrentTime(time_1); CHECK_MSTATUS_AND_RETURN_IT(status); mArr.append(bonePath.inclusiveMatrix()); } return MS::kSuccess; }
