Query which file type / file translator was used to create a reference?
barnabas79
barnabas79
If I have a loaded reference node, I would like to find what the file type was - ie, if the reference was created with this command:
file -reference -type fooImporter "/path/to/myFile.foo"
I want to query myFileRN to get "fooImporter".
Ideally, I'd prefer an OpenMaya solution, but mel / maya.cmds would be fine too...
cheng_xi_li
Autodesk Support
Autodesk Support
I think you can use MFileIO::getReferneceNodes and MFnDependencyNode::typeName to get the referencing nodes' names.
If you are going to write in Python, the MFileIO isn't available. You can use cmds.file to query all references instead.
Yours,
Li
barnabas79
MFnDependencyNode::typeName() gives the maya node type name - ie, "transform", "joint", "mesh", etc.
I'm looking for the translator / MPxFileTranslator name - ie, "mayaAscii", "mayaBinary", "abcImport", etc.
cheng_xi_li
Autodesk Support
Autodesk Support
In that case, you can use cmds.referenceQuery to get the filenames and use file -q -typ file name to get the file type. You could also get a custom MPxFileTranslator* with MFileIO.
If you know the plugin name of the translator you are using, you can use plugininfo with translator flag to get the translators' name.
Yours,
Li
barnabas79
Multiple plugins / file translators can register themselves for the same extension - thus the need to know what the exact translator used was.  (In my case, there are multiple translators for the ".abc" format, and I want to know which was used.)
Getting an MPxFileTranslator*, while still not ideal (ie, wouldn't work for any built-in maya types), would probably be good enough.  However, for my needs it would probably be good enough.  Is the method you're referring to MFileIO::beforeReferenceUserFileTranslator()?  If so, this (and many other referencing callbacks) have an achilles heel - there's no way I know of to directly query which reference is being currently loaded in a unique way.  You can use beforeReferenceFilename() to get the name of the file, but that's not unique - you could can reference in the exact same file multiple times, and I don't know how to distinguish which reference we're currently loading.
Having said that - in order for that to be an issue, it would mean that we'd have to be loading the exact same file multiple times, but with DIFFERENT translators... ie, do something like:
file -reference "myFile.abc" -namespace "nativeAlem" -type "Alembic";
file -reference "myFile.abc" -namespace "usdAlem" -type "pxrUsdImport";
...which seems unlikely. So this may be our best option...
cheng_xi_li
Autodesk Support
Autodesk Support
Yes, I was referring to MFileIO::beforeReferenceUserFileTranslator. The isn't a direct query available right now.
I am afraid there are no other methods to get the translator type of a reference node.  Sorry for the bad news.
Yours,
Li
barnabas79
Gotcha - well, thanks for the info!  beforeReferenceUserFileTranslator isn't perfect, but will hopefully be good enough!
