python script that adds Arnold node - hypershade not updating
When executing this simple script that adds an Arnold standard surface node:
________
for item in selection:
     cmds.createNode( 'aiStandardSurface', n=item )
_______
Hypershade does not update the "Materials" tab to indicate the material is there. It shows up in the in the outliner with (DAG objects only = FALSE).
How do I add the shader to Materials tab???
Thanks.
sean.heasley
Hi @Anonymous
How are you using this script?
I just made a new scene with a basic object and tried running the script but only get syntax errors.
mspeer
Hi!
Just creating this one node is not enough.
If you use the UI to create a material there is a lot more going on like creating additional nodes and make connections to other nodes.
These nodes and connections to these nodes are needed:
- ShaderGroup
- materialInfo
- renderPartition
- lightLinker
- defaultShaderList
If you want to work with single nodes, use the Node Editor.
Edit:
If you only need the visibility in Hypershade use command shadingNode, this creates a connection to defaultShaderList:
https://help.autodesk.com/cloudhelp/2015/CHS/Maya-Tech-Docs/CommandsPython/shadingNode.html
Awesome! This saves a line of python. Instead of creating the node and doing a connectAttr to the appropriate list, I can just create and connect in one line. Thank you!
