Python Module not found in pref/scripts foler
brobes05
brobes05
I purchased and downloaded a python module containing .pyc files called PinToCurve and placed its folder 'PinToCurve_1.6.5' in the maya/prefs/scripts directory at : C:\Users\brobe\Documents\maya\2018\prefs\scripts
Maya cannot find these files when I import PinToCurve and run the .ui function. (which my computer thinks is a 3ds max file user interface file)
The module consists of .pyc files and looks like jibberish if I load it directly into the script editor. This would wosif I could copy the code into the script editor.
I have attached images which should illustrator the issue more clearly.
I appreciate your help any ideas would be very helpful. Thank you. PINTOCURVE.PNGPINTOCURVE2.PNGPINTOCURVE3.PNGPINTOCURVE4.PNGPINTOCURVE5.PNGPINTOCURVE6.PNG
cheng_xi_li
Autodesk Support
Autodesk Support
Please put it inside maya/Python/Lib/site-packages.
Yours.
Li
brobes05
This is magical.
Works like a charm (not sure why), but content nonetheless.
Thank you.
