Python import command, for a file in a subfolder
grendizerus
grendizerus
Hello, in my Documents\Maya\scripts folder, I have a python file called "rr_main_curves.py".
To start this script, in Maya, I paste these 2 lines of code and then I run the script:
import rr_main_curves
rr_main_curves.window_creation()
But now, I want to put this script and all attached scripts in a subfolder of Documents\Maya\scripts : this subfolder would be called "RigBox".
So that's what I did, but now my "import" command does not work. I tried many things but they don't work:
import RigBox/rr_main_curves
import RigBox\rr_main_curves
import ./RigBox/rr_main_curves
import .\RigBox\rr_main_curves
HELP!!
Thanks 🙂
DS
Kahylan
Hi!
If RigBox is in your script folder you should be able to import it using:
import RigBox.rr_main_curves
Unless you are in a Maya version prior to 2022, in which case the normal import command should work since Python 2.7 doesn't need the sub directory if there is only one module in the scripts folder with this name.
I hope this helps!
grendizerus
amazing! thanks!
I do have many module in the scripts folder , many *.py files linked to the main one.
