Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
python doesn't work
python doesn't work
sohei.hori
python doesn't work
sohei.hori
I'm not good at English.
It can be difficult to read. excuse me.
I'm learning Python using MAYA.
what i want to do
I want to change the thickness of NurbsCurve all at once.
Please have a look at the code and tell me what is wrong.
Thank you for watching.
from maya import cmds
nodes = cmds.ls(selection=True)
for node in nodes:
 if cmds.window(ram, exists =True):
    cmds.deleteUI(ram)
ram = cmds.window( w=300, h=300 )
cmds.columnLayout( adj=True )
cmds.getAttr(node + ".lineWidth")
cubW = cmds.floatField(pre=1, editable = True, value = 1,)
cmds.button(l= "Apply", c="LW()" )
cmds.showWindow(ram)
def LW():
    myCubeWidth = cmds.floatField(cubW , q = True, value = True)
    finalThickness = cmds.setAttr(node + ".lineWidth", n= "LW")
Kahylan
Hi!
There were quite a few problems,
1) You were setting a new window for each curve, changing all their values at once would not have been possible.
2) you were referencing the attribute node, in a function that did not know about it
3) you didn't provide a value in the setAttr command
And probably some more.
Here is how I would suggest your code should look like.
if cmds.window("ram", exists =True):
    cmds.deleteUI(ram)
ram = cmds.window("ram", w=300, h=300 )
cmds.getAttr(cmds.ls(sl= True)[0] + ".lineWidth")
def LW():
    lineWidth = cmds.floatField(cubW , q = True, value = True)
    for node in nodes:
        cmds.setAttr(node + ".lineWidth", lineWidth)
I hope it helps!
