Python API 2.0, custom node gets a warning: # Warning: Unrecognized node type 'NumberToStringNode'; preserving node information during this session. #
g2m.agent
g2m.agent
Windows 10, Maya 2020.2
custom node gets a warning when loading:
and my custom node is considered an "unknown" node.
I really don't understand why. this is my code:
import maya.api.OpenMaya as om # Maya Python API 2.0
# tell Maya use Python API 2.0
# Both methods have the same result.
# maya_useNewAPI = True #  (Maya 2019+)
def maya_useNewAPI():
    pass
# nodes  # ------------------------------------
# NumberToString
class NumberToStringNode(om.MPxNode):
    TYPE_NAME = "NumberToString"
    TYPE_ID = om.MTypeId(0x0007F7F8)
    def __init__(self):
        super(NumberToStringNode, self).__init__()
    @classmethod
    def creator(cls):
        return NumberToStringNode()
    @classmethod
    def initialize(cls):
        pass
# plugin ------------------------------------------------
# Initialize the plug-in #
def initializePlugin(plugin):
    vendor = "myName"
    version = "0.0.1"
    plugin_fn = om.MFnPlugin(plugin, vendor, version)
    # register nodes
    try:
        plugin_fn.registerNode(
            NumberToStringNode.TYPE_NAME,
            NumberToStringNode.TYPE_ID,
            NumberToStringNode.creator,
            NumberToStringNode.initialize,
            om.MPxNode.kDependNode)
    except:
        om.MGlobal.displayError("Failed to register node: {0}".format(NumberToStringNode.TYPE_NAME))
    print("hello maya")
# Uninitialize the plug-in #
def uninitializePlugin(plugin):
    plugin_fn = om.MFnPlugin(plugin)
    # deregister nodes
    try:
        plugin_fn.deregisterNode(NumberToStringNode.TYPE_ID)
    except:
        om.MGlobal.displayError("Failed to deregister node: {0}".format(NumberToStringNode.TYPE_NAME))
tdHendrix
Tried it in Maya 2020.3 and it works for me. I used this command to create the node:
createNode NumberToString;
Greg Hendrix - Senior Technical Animator
LinkedIn : Twitter
