Put expression into multiple objects with script?
Hi bit of a noob question...
I'm trying to get to grips with MEL, I have an expression controlling the rotation of an object which I now want to use in 100+ other objects.
I need to write a script that will put this expression into all of the selected objects.
Does anyone know how do I do that? Any help greatly appreciated.
Here's a very simple example:
string $sel[] = `ls -sl`;
for ($tmp in $sel) {
expression -s ($tmp + ".translateX=frame");
Thanks very much for getting back to me. This works fine by itself but in my case I want to control several attributes, some of which depend on if/else statements?
This is a small part of the original expression. (I was thinking of posting the entire expression but its not exactly short.) I was testing it on a cube. hence pCube 1 is written everywhere.
if ($randA == 0)
pCube1.rotateX = $rotateX;
pCube1.rotateY = $rotateY;
else if ($randA == 1)
pCube1.rotateZ = $rotateZ;
__________________________
This is what I changed it to.
if ($randA == 0)
expression -s ($tmp + ".rotateX = $rotateX");
expression -s ($tmp + ".rotateY = $rotateY");
expression -s ($tmp + ".rotateZ = $rotateZ");
Basically I've replaced "pCube1" with the "expression -s ($tmp" etc
I also put this part at the begginning of the script.
I'll say now that it didn't work with my expression. So I assume thats just because I've used the script incorrectly.
How would I go about integrating it?
Thanks.
Success
I figured out what I was doing wrong.
This is the script that I used.
string $mySel[] = `ls -sl`;
for ($i=0; $i<size($mySel); $i++)
expression -s "The entire expression goes here" -o $mySel -ae 1 -uc all ;
What I done was create a cube. Go into the expression editor and asign my expresion to the cube. Then looked in the script editor to see what it generated. (in this case... expression -s "The expression I created" -o pCube1 -ae 1 -uc all 😉 I then Swapped pCube1 for $mySel and put the other bit of script in front. I realised that you cant put any returns in the expression of the script, and that you had to replace them with \r.
Thanks agian.
